Hello Lew,
Any idea of the noise level? The low profile units generally have a smaller plenum and generate more velocity creating a higher sound level. I consulted with the engineering staff at RVP about five years ago and they did not have solution for sound levels at that time. Thanks for the update
The roof top AC units are designed to be through aways. If you get a new one, which you may have to, you should get a high efficiency unit. With 4-5 amp less power draw it will help when running it on your generator.
