Old 09-04-2009, 12:47 PM   #1
1965 22' Safari
California , Kentucky
Need help with new furnace install
I am installing a new Suburban NT30sp in my 1965 Safari. It fits on the original pan but the pan was made to slope to the outside wall by 1". Is it OK to install a furnace that is not level? Maybe they did this because of the curve of the outside skin?
RiverRat is offline   Reply With Quote
Old 09-04-2009, 12:56 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I had to install nt30sp on an angle to fit the old hole and angle of the trailer and it works fine. I have a pic in my Images if you want to see the finished job. I can post an outside photo if you want. I had to build up from the original nt22 blower box that I took off the old furnace.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 09-04-2009, 05:12 PM   #3
1965 22' Safari
Yes, I would like any pics available.Thank you for the prompt reply as I am trying to complete this over the weekend holiday. My e-mail is oyorio23@fuse.net John G
Old 09-05-2009, 08:01 AM   #4
1967 22' Safari
1960 Caravel
Images: 8
Hi John, My separation for this conversion was this post. http://www.airforums.com/forums/f427...0sp-41537.html Instead of a hack saw to take the air box off the the furnace i used a air hammer with a chisel to break the weld.
Photos: 1 old furnace; 2 new intake-exhaust done; 3 new furnace on old air box; 4 angle it's mounted on.
I set the old air box in place on the floor where I wanted it then set the new furnace on top. Using pieces of wood I shimmed the new furnace into the correct angle to fit the old holes(some adjusting needed) and the angle of the trailer. Once I had everything fitting correctly I used the parts of the old furnace for the gaps in the back (see link above) and bent some sheet metal for the sides. I took the wood out once I had the side pieces attached. I used pop rivets for this but sheet metal screws will work fine it's just what I had that was handy. Be careful where you drill into the new furnace. Keep in mind that this does not have to airtight it's just hot air. I did use Vulkem (Tempro) to fill any gaps that I saw. Hope this is somewhat clear. If you lived closer I'd come over and help. Good luck!
ID:	86654   Click image for larger version
ID:	86656   Click image for larger version
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
How NOT to install. Inland RV Center, In Furnaces, Heaters, Fireplaces & Air Conditioning 12 05-21-2009 08:43 PM
Fan Install themartaman Roof Vents, Skylights & Fans 22 06-22-2006 10:48 AM
furnace install knjobrien5 Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-09-2005 01:51 PM
Should I install AC myself? Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-22-2004 11:26 AM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
