Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 03-31-2007, 08:36 PM   #1
Sunset Coast
Sunset Coast's Avatar
Profile:  1988 32' Excella
Benton Harbor , Michigan
Need help with furnace dimensions
I tried to post this once but got a "Server too busy" message. My '88 Excella has a Suburban NT-35K furnace that I am considering replacing but the available new furnaces appear to not fit the space of my old one. Does anyone have the dimensions of the location of the inlet and exchaust pipes relative to the box for the NT-34SP and the SF-35F? It appears that the NT-34SP may have these pipes higher than my current box. The inlet is about 4" up from the floor. Also, my current setup has two exhausts and one inlet, so I guess I would have to plug the second one.
Sunset Coast is offline   Reply With Quote
Old 03-31-2007, 09:32 PM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Hi 'Coast,
It looks like the newer units will not fit your existing outlets based on my observations in servicing many of them. You might try the Suburban website for dimensional drawings, or call their tech line for more info.
New units can mount either from the inside or outside of the rig. You might be OK if you get an exterior mounting model and get a brushed stainless or aluminum cover for it. It would blend right in to your exterior of the trailer, and you would have a perfectly aligned cover too.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 06:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 10:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 09:29 PM
test
