Old 05-20-2011, 08:39 PM   #1
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Question Need help with Armstrong TR 21-12 problems please
I have a small problem. Whenever it rains, the A/C circuit pops the GFCI of the house circuit I'm plugged into. It only happens when it rains. When it dries out, it works just fine. If I shut off the A/C breaker at the box, I can reset the GFCI and all the other 110 outlets work fine in the trailer. Even with the A/C off at the thermostat, when I turn on the CB at the CB box it will trip the GFCI. Not the main CB, just the GFCI at the outlet. I have removed the A/C shroud and opened up the little wiring box and tightened all the wire nuts and made sure everything was in order. I found one wire a tad loose the other day so I thought I had the culprit, but It just rained and did it again. I sealed the little Jbox with sealant when I closed her up. The A/C is the original Armstrong unit. Any ideas?
Lance
Top is offline   Reply With Quote
Old 05-20-2011, 10:25 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
GFCI breakers trip when a imbalance exists between the current in the hot leg and the current in the neutral leg. Some things to check:
1) make sure relay/starter on A/C is interrupting hot leg, not neutral leg.
2) look for leakage paths on any of the wiring to the relay/starter. Note that dirt, wetness, etc. can easily conduct the milliamp necessary to trip the GFCI.
Another way of doing this is to get a mister bottle on a dry day and gently mist connections, etc. to find the leakage path. Plug something into the 110 outlet in the trailer so you know exactly when it trips. Of course, be careful while doing this....
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 05-20-2011, 10:33 PM   #3
Ottawa , ON
Wonder if the GFCI unit is marginally defective?
Did you try replacing it?
Old 05-20-2011, 10:56 PM   #4
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I had that problem in a buried line once. When it rains, it trips. Best bet is to find the wire that collects rain and replace it or waterproof it. Probably be a small slit in the protective covering from a siding nail that you can't find.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 05-20-2011, 11:18 PM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Do you have an outside 110v outlet? Considering your symptoms I would start there and inspect the gaskets to be sure moisture isn't getting in.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 05-21-2011, 05:11 AM   #6
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks for the help guys.
Barts,
I'll try those things you mentioned.
Aage,
I haven't replaced the outlet. I don't have any problems from it any other uses. Just when I have the trailer A/C circuit breaker on and it rains. When it trips I can shut off the A/C CB, reset the GFCI and everything else works fine.
NevadaGeo,
I have it isolated to the A/C circuit of the trailer. I don't think it is anything with the house or the house wiring. I have a 100' extension cord that I use to plug the trailer into an outlet inside the house.
YankeeDoodle,
My trailer doesn't have an exterior outlet.
I guess I need to do some more trouble shooting.
Lance
Old 05-21-2011, 07:44 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You'll want to pull the shroud off the A/C unit. Check the capacitors and make sure they aren't in a position to get water on top of them, where the connections are. Our '72 had this problem, I found out about it one day when it had rained, and I touched a metal part of the air conditioner.
Old 05-21-2011, 09:36 AM   #8
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks for the help y'all. I think I've fixed it. These two wires were draped down over the blower motor sitting in a puddle of water. The black rubber boot for the (capacitor? Relay?) Is all torn up and was puddling water where these two wires connect to the componnent.
I cut off the old blade connectors and used two of these $1.10 crimp/solder/heat shrink super connectors I bought at Fastenal. I did my best to seal up the top and sides of the rubber boot. I'll have to keep an eye on it. It seems to be working fine right now.
Thanks guys. Once again the Forum knowledge base comes through!
ID:	130319   Click image for larger version
ID:	130321   Click image for larger version
Lance
Old 05-21-2011, 01:27 PM   #9
Ottawa , ON
Congratulations on finding the fault, Top. It does sound logical, that the wires that got a soaking would trigger the GFCI.
Here's a tester that I think I will put in my toolbox for future questions like you were going through. It tests for seven conditions and indicates faults by simple LEDs, hopefully it would have given you a hint as to what was going on.
"GFCI and receptacle tester tests ground fault receptacles by overloading circuit and tripping GFCI."
Old 05-21-2011, 05:19 PM   #10
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
More tools=good
Thanks Aage! I'll see if I can find one of those. I'm not an electrician, but I do make them do push ups now and then. Electricians are always the ones in the smoke break area at the hangar. Whenever you see three Soldiers in my unit wasting time, two of them are electricians. The third is usually a pneudraulics (aircraft plumber) mechanic. You know what I think of plumbers these days!
Lance
Old 05-21-2011, 05:35 PM   #11
x
XXXX , XXXX
Lance I'm LMAO about the pushups. Electricians are the only ones that get paid to pull their wire all day long.
Plumbers only need to know the two rules of plumbing.
1) poop flows downhill
2) Payday is Friday.
wasagachris is offline   Reply With Quote
Old 05-21-2011, 05:44 PM   #12
Missouri Valley , Iowa
Chris,
I heard the same plumbers admonitions with one more bit of advice : Don't chew your nails !!!!
Dan
Farmer Dan is offline   Reply With Quote
Old 05-21-2011, 06:03 PM   #13
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
My Dad always said that about plumbers when I was a kid. After actually trying to find a good plumber, I know what he was talking about!
Lance
Old 05-21-2011, 06:08 PM   #14
Well Preserved
1993 21' Sovereign
I have always heard:
Hot on the left
Cold on the right
Crap flows downhill
Most plumbers around here only have one out of those three correct
armstrong, wiring, gfi
Free 1973 Armstrong A/C parts w/shipping costs rich2002 Furnaces, Heaters, Fireplaces & Air Conditioning 13 06-19-2017 11:43 AM
Armstrong VCT - Any gluing issues with Cold? robwok Floor Finishes 4 08-08-2013 11:49 AM
Armstrong 10 AC Unit BadKarma226 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-11-2011 08:50 AM
