Old 05-21-2011, 06:19 PM   #15
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Ha Ha! That's a funny one! So Terry, what is the little thing on the top of the motor called?
Lance
Top is offline   Reply With Quote
Old 05-21-2011, 07:53 PM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That's a capacitor. If you grab the terminals, it can really "light up your life".
Old 05-21-2011, 07:59 PM   #17
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
It did just that a few days ago when I was prodding around with the juice on!
Lance
Old 05-21-2011, 09:57 PM   #18
soldiermedic's Avatar
Florissant , USA
Cardiac Dysrhythmias.....shocking
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-24-2011, 08:12 PM   #19
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Angry No rain just heat
Looks like another problem with the A/C and popping the GFCI. Today after having the A/C on for about six hours, the GFCI popped again. No rain. Just a lot of heat. I shut off the A/C and moved the thermostat to the hottest setting. I reset the GFCI and turned on the A/C/ The blower fan came on and ran fine. When I turned the thermostat down, the compressor kicked in and immediately the GFCI popped. That pretty much narrows it down to the compressor and compressor wiring. Maybe something melted. Any ideas?
Lance
Old 05-24-2011, 08:24 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
How big
What size is the circuit breaker that keeps tripping?
Old 05-24-2011, 08:42 PM   #21
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
It is a 20A breaker. The breaker doesn't pop. Just the GFCI at the outlet where it is plugged in.
Lance
Old 05-24-2011, 08:45 PM   #22
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What size is the GFI?
Old 05-24-2011, 08:50 PM   #23
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I took the cover off and looked at it. The receptacle is stamped with "Class A GFCI 20A 125V"
Lance
Old 05-24-2011, 09:40 PM   #24
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
I'm "crackin'" up over the plumber jokes. Wink
This may sound weird, but have you put a volt meter to your AS' skin?
A switched neutral and hot running thru a gfci can actually make your trailer a ground.
Phrunes is offline   Reply With Quote
Old 05-24-2011, 09:50 PM   #25
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I have not checked the skin with a meter. I'm sure that the wiring is correct. I did check that today.
Lance
Old 05-24-2011, 10:28 PM   #26
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Not enough Power
I think the 20 amp breaker is your problem. Do you have the proper size shore power cord and wiring to a 30 amp receptacle to run it from a 30 amp breaker? Normally in order to run your A/C, you need a 30 amp service. If you try to run it under powered, you can do damage to the A/C motors.
Old 05-24-2011, 11:11 PM   #27
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
I have it isolated to the A/C circuit of the trailer. I don't think it is anything with the house or the house wiring. I have a 100' extension cord that I use to plug the trailer into an outlet inside the house.
Hi, this might be part of the problem?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-24-2011, 11:12 PM   #28
Maniacal Engineer
barts's Avatar
Menlo Park , California
Hmmm... the original poster said:
Even with the A/C off at the thermostat, when I turn on the CB at the CB box it will trip the GFCI.
so the issue is leakage current between hot and ground causing the GFCI to trip; it has nothing to do with an overload condition. Your point is well taken that running A/C systems w/ marginal power is hard on the motors, though.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
armstrong, wiring, gfi
Free 1973 Armstrong A/C parts w/shipping costs rich2002 Furnaces, Heaters, Fireplaces & Air Conditioning 13 06-19-2017 11:43 AM
Armstrong VCT - Any gluing issues with Cold? robwok Floor Finishes 4 08-08-2013 11:49 AM
Armstrong 10 AC Unit BadKarma226 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-11-2011 08:50 AM
