Originally Posted by cheetah1
Scoutx - Thank you for these links. They are proving to be invaluable!
Anytime.
Looks like the electrical in mine is going to get a total revamp.
I have changed the blower motor. I will shortly replace the compressor, and will include a reversing valve at the same time.
Among the electrical changes which will not include replacing the 2 wire thermo wire are:
1) replace on switch with DP3T on/off/on. To control on/off and select either heat or cooling mode.
2) add additional DP3T on/on/on to give me access to all 3 fan speeds.
3) add relay to thermo wire to allow standard thermo in 2 wire mode to control heating and cooling without have to alter thermostat. Reverses on/off logic in one mode but not the other.
4) run all exterior wires through water tight conduit to junction box.
5) run addition lines as needed between upper and lower unit.
6) add delay on make breaker to provide a compressor delay when power is restored or you switch between modes ( power turned off as you move through middle position of power switch)
7) add a timer relay to thermo control to prevent short cycling the compressor.
8) may add a switch to allow fan to cycle with compressor or remain on all the time.
Finally. I added a rain shield to the blower shaft to help protect motor from the rain. 7" dome of black plastic that press fits on the upper shaft to act like an umbrella.
