Old 11-06-2010, 12:55 PM   #1
Nice guy
2012 30' International
Asheville , North Carolina
need a180 degree bracket for cat heater?
Does anyone have any idea where I can find a bracket to mount on catalytic wall heater that can swing 180 degrees. Any experience with them standing up to the jostling a trailer gets while towed?
On a related note...thinking of a Camco Wave 6 no vented vs the Platinum Cat heaters as I do not one to put a hole in the trailer to vent it outside? Any experience with either product wuld be appreciated?
Ashe
ashe is offline   Reply With Quote
Old 11-06-2010, 01:21 PM   #2
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
I have been thinking of using the Peerless SA740P swiveling wall mount used for flat screen TVs to mount an Olympic Wave catalytic heater. You will have to drill four holes in the back of the heater for the nuts and bolts. You might have to disassemble the heater to do that.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 11-07-2010, 08:45 AM   #3
Nice guy
Thanks Bob, that is a good idea to check out.
Vented Cat Heater Old Nuke Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-22-2010 10:08 AM
35 degree down angle worth $800.00? SilverHoot Axles 13 08-31-2009 04:51 PM
Olympian Wave 6 Cat Heater wingfoot321 Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-19-2008 08:29 AM
Hehr glazing strip...45 degree or? Zstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-02-2008 10:27 AM
Cat Heater in '63 Bambi kaffe_1477 Water Heaters, Filters & Pumps 4 02-06-2007 08:26 AM
