Old 08-15-2006, 09:10 AM   #1
Gambierite
davida's Avatar
vancouver , BC
Mystery Part
I found this part in my '79 sovereign (new to me). I assume from the description that it's an on board "controller" for the furnace.
As far as I could tell both the heat and AC worked, so I don't know why a PO had bought it (16 years ago!).
Any reason I should hang on to this part?
--david
ID:	24745   Click image for larger version
davida is offline   Reply With Quote
Old 08-15-2006, 09:20 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
It might be the old one, the PO might have kept it around for some reason or other, after installing the new part that you have the invoice for.
It's called "separation anxiety".......
Uwe
www.area63productions.com
Old 08-15-2006, 03:42 PM   #3
Suburbia , Sunny So Cal
If you toss it you will need it within 30 days. If on the other hand you keep it. You will never need it and save yourself time and effort. Leastways thats how it works around my house.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 08-15-2006, 04:32 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
PM me letting me know where you are and I'll pay you to send it to me. I need one right now but this maybe the broken one. I am willing to try it.
Old 08-16-2006, 11:04 PM   #5
1960 24' Tradewind
santa barbara , California
davida,
That big yellow capacitor could still have some stored voltage in it .Read alot
about capacitors in old antique radios and they are dangerouse to your life .
be careful and don't touch it .It may not be ,but better to be safe.Lewster
would know for certain ,I don't for certain .
Scott
scottanlily is offline   Reply With Quote
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 05:15 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Skinner air valve part # benbailey Airstream Motorhome Forums 1 10-19-2002 09:03 AM
