Old 11-22-2010, 10:30 AM   #1
1976 25' Tradewind
chapel hill , North Carolina
My heater mister buddy
My 76 25 footer is boondocked and winterized. The furnace does not work and the previous owner ran a gas line from the tanks which exited below the sliding door for the fuses. The line is a copper 3/8 inch capped with a 1 inch cap. I have a Mister Buddy heater,the small one, which I know many ASers have used. It does a good job heating, but the one pound propanes are too expensive. Any ideas about how to connect the standard Mr. Buddy hose to the copper line. Is there an adapter of some sort?
Jpalm
jpalm1048 is offline   Reply With Quote
Old 11-22-2010, 10:48 AM   #2
arodriguez60's Avatar
2008 27' Classic FB
1959 22' Flying Cloud
fairview , New Mexico
Images: 85
There is an adapter hose that will fit in place of the bottle and hooks to a 20# tankhttp://www.campingworld.com/shopping/item/propane-hose-assemblies-with-acme-nut/30338
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 11-22-2010, 10:50 AM   #3
Naper's Avatar
Loretto , Ontario
Be careful !! I wouldnt use a propane heater in an inclosed area. The furnace in your AS uses combustion air from the outside. Mr. Buddy will eat up the oxygen in your AS and replace it with carbon monoxide real quick.
Naper is offline   Reply With Quote
Old 11-22-2010, 11:10 AM   #4
x
XXXX , XXXX
Those heater do not produce carbon monoxide they put out crabon dioxide. However once it consumes enough oxygen in the room and the combustion process does not have enough oxygen to burn clean then it will start producing carbon monoxide. If you open a roof vent and allow the carbon dioxide to exit the trailer(carbon dioxide is lighter than air) then the heater will always have enough oxygen to burn clean.
So it is safe to use these heaters for a very short term and agree not to use them as your primary source of heat in the trailer.
wasagachris is offline   Reply With Quote
Old 11-22-2010, 11:46 AM   #5
1978 31' Excella 500
Tuttle , Oklahoma
I respectfully disagree.
Carbon dioxide (CO2) is heavier than air and will sink in an undisturbed environment.
This is one reason why it is an effective fire extinguisher.
1bbboomer is offline   Reply With Quote
Old 11-22-2010, 03:21 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Coleman ProCat
Here's the small Coleman Catalytic Heater we use when dry camping in cold weahter .... heats up the Bambi nicely...we never let it run while we sleep and you must have proper ventilation...we like this model because it has a battery-driven fan (two Ds). It runs off standard propane canisters but I believe you can get a tank adapter.
Name:	Coleman 5053A751 ProCat Perfectemp Cat Porpane HeaterBack.jpg
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 11-22-2010, 03:25 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I use the Mr. Heater Buddy heaters for a variety of uses, including camping. They have a low oxygen shut down on them. However providing some source of fresh air is a requirement of safe use.
We have 4 of them and have used them in the past during a power outage to keep the house from freezing up. We hang a 20# LP tank outside the window sill on the window box brackets (LP tank is in a milk crate) run the hose in through the window. I also have one mounted on the wall in my shop as a back up heater too, it is plumbed to a 100# tank that sits outside.
Aaron
WBCCI #XXXX AIR #2495
Old 11-22-2010, 03:48 PM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Ok everybody agrees on propane producing cheap heat fast and using up oxygen to make CO2 and when they malfunction CO. Open window allow more air in but no one has mentioned the H2O produced when propane is burned in this small space, could be a problem over time.
Old 11-22-2010, 03:59 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
This has not been a problem in our experience but then we only use it for short time...we always have a vent open somewhere, too and that no doubt helps...
AirForums #21900
PastPrez, 4CU/WBCCI
Old 11-22-2010, 04:20 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Usually pretty dry around here in the winter time, so I have never noticed a moisture issue.
Aaron
Old 04-24-2011, 03:51 PM   #11
nevada , Nevada
Big Buddy or Little Buddy
Was almost set to pull the trigger on a little buddy Mr. Heater for my 26' Overlander thinking that running it on high would be sufficient enough with outside temps around 40 degrees and looking to be about 62 inside. But now I'm reading the Big Buddy may be more convenient to hook directly up to the trailers regulated gas pressure by using the bypass regulator connection on the back of the Big Buddy.
Also, not knowing how long it would take the little buddy to heat the trailer up if we came back to a static 45 degree interior temp wanting to go to bed in 30 minutes, perhaps the Big Buddy would be the better choice to quickly warm the trailer up at 18,000 btu before turning it down to 9000 for night time sleeping with the roof vent and side window cracked open.
wolfpack is offline   Reply With Quote
Old 05-02-2011, 09:46 AM   #12
blickcd's Avatar
Milford , Ohio
I've used one of those heaters in a deer blind once and it was really effective. My question about running the trailer's propane line to it is, what gas pressure does that heater need to run at peak performance?
The screw-on tank would seem to give varrying pressures as it runs out. Does the heater somehow regulate the pressure?
blickcd is offline   Reply With Quote
Old 05-02-2011, 10:20 AM   #13
1977 Argosy 24
Milltown , Wisconsin
Life is too short to risk dyeing in an Airstream. Spend the money and fix the old furnace or buy a new one, don't risk your life to save a few bucks.
ventport is offline   Reply With Quote
Old 07-08-2011, 11:15 PM   #14
darryl97420's Avatar
1974 Argosy 28
Coos Bay , Oregon
I have a big buddy and it will warm things up real quick. Where do you guys put your heaters while using them? They put out loads of heat on to the surface they are set on and I cracked my dining room table last winter. So I don't want to use it on the floor. Where do you park your heater?
darryl97420 is offline   Reply With Quote
Old 12-06-2011, 10:34 PM   #15
1974 Argosy 28
Coos Bay , Oregon
Its 33degrees tonight and was 29 this morning and our Mr. Heater Big Buddy worked great keeping us warm all night. Ran it on high (18, 000 btu) for about 15 minutes then down to low (4,000btu) all night and woke up to a comfy 68. I prefer a cooler space to sleep in but keep it warmer for my daughter. Its hooked up to a #20 lb tank for plenty of propane and a small power cord to save on batteries. This thing was a great investment and has proven itself during this cold snap.
Old 12-06-2011, 11:11 PM   #16
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
Please be careful,,, these things can be totes dangerous ie: Low O2, Hi CO, not to mention fire hazard, We don't want to loose ya'
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Water heater won't lite imuir Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Airstream water heater door LKSD Water Heaters, Filters & Pumps 9 03-23-2011 04:46 AM
Water Heater suggestions for '64 Overlander robwok 1960 - 1964 Overlander 4 03-02-2011 07:27 PM
Basic h/w heater question (empty tank) TennisMan Water Heaters, Filters & Pumps 4 03-01-2011 02:19 PM
