Old 04-03-2013, 11:36 PM   #15
Made these for my suburban, used #14 stainless screws to hold them in the center, cost $1.50 and 30 mins labor.
0557 is offline   Reply With Quote
Old 04-04-2013, 04:06 AM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
One reason why commercially-available screens have a dome shape rather than being flat is called "equivalent opening size." By making them in a dome shape, you can make sure that the total size of the screen openings is as large or larger than the furnace exhaust opening. This ensures that the screen does not create an obstruction. The larger the mesh size, the smaller the dome shape needs to be to provide the right equivalent opening size.
The flat screens that 0557 made do provide an obstruction to the exhaust. The equivalent opening size is reduced by the wires of the screen. His screens may work for him, but as a mechanical engineer, I can't recommend it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-04-2013, 03:19 PM   #17
They do work, and can be removed in the winter
when wasps are not building nests.
Old 04-05-2013, 06:21 AM   #18
If you remove the screens before firing up the furnace, that's a different case. If you're going to do that, why use screen at all, when a solid metal cap will not only keep out wasps, but keep out water or dust as well? After all, you could remove a solid cap just as easily as you remove a screen.
WBCCI #1105
TAC LA-4
Old 04-11-2013, 06:51 PM   #19
I typically use 3 inch foil tape for that
Old 04-11-2013, 06:57 PM   #20
Ottawa , ON
I remember when reading the owners manual for the new Suburban I installed last spring that they specifically mentioned not to use screens over the intake and exhaust.
However, if one remembers to remove them before use it obviously wouldn't be a problem.
Old 04-11-2013, 09:45 PM   #21
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
There are three stainless steel replacement doors as options for the new Airstreams and a third party makes the bulbous screen shields to keep the wasps out of the gas appliances.
Old 04-12-2013, 11:21 AM   #22
1981 31' Excella II
New Market , Alabama
Here is a place where you can order stainless steel screens. I need to do this soon. My furnance was almost completely blocked by mud dubbers nests.
McMaster-Carr
Perry
Old 04-12-2013, 01:03 PM   #23
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I put a dog flea collar in the opening every time I return from a trip.
Started this after a problem with mud dabbers never had a problem since using the flea collars. I think they keep out wasp also.
Garry
Old 04-12-2013, 02:33 PM   #24
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I've used the standard screens you can buy in RV stores over the furnace and water heater for years without problems. The springs they come with are hard to connect, so I just attached them with mechanic's wire. That type of wire rusts and has to be replaced eventually. The springs can snap out of your hand and scratch the aluminum. The screens are overpriced, but so is everything else at RV stores.
I wish they made them for the fridge vent, and maybe they do at even a higher price.
Gene
Gene
Old 04-12-2013, 02:59 PM   #25
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I cut a square of furnace filter...stays put until warm is needed.
Have forget'n to reinstall after use but WNY wasps are only good to 45mph, they couldn't keep up on the Thruway.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 04-12-2013, 03:20 PM   #26
Master of Universe
Gene's Avatar
They'll get you at the toll booth.
Gene
Gene
