Originally Posted by jpalm1048
My 76 twenty-five's furnace is gone. I've decided not to replace it and instead have had a gas line from the tanks installed below where the stove is. I plan to connect a small propane heater...a MR. Heater brand has been recommended. Question anyone else done something similar and secondly how many BTU would it take to heat the 25 in moderate southern winters?
Also, apparently got to get the heads on the original propane tanks changed. How does that happen?
Jpalm in NC
Keep in mind, that should your coach be exposed to freezing weather, your proposed heater will not prevent a freeze up.
Your heating system, as designed, forces some hot air around the water and holding tanks, as well as the water lines in the coach.
If the heat is not circulated to the tanks by forced air, or copper tubing, should there be any water in those tanks, or water lines, it will freeze.
That in turn, will cost considerable money to fix.
You can avoid that issue if you properly winterize the trailer.
