Old 07-26-2009, 07:10 PM   #15
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
What do you need to do to the Vista Views - I heard the PO did a really nice job creating making a seal....
The Vista Views on your trailer are very easy to fix - there is an inside ring you can remove, that removes the inner glass
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 07-26-2009, 07:29 PM   #16
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Hi Ken!
The PO did nothing but outstanding work.
The coating between the windows (on the glass side)has turned yellow and is falling off. The tint sheet on the plexi has welded itself to the plexi and has bubbled, most likely to the heat. I have the curbside ring removed and my plan is to clean the glass surface, replace the plexi with new pieces and install new butyl tape between the two windows.
BTW, the ring and the plexi were not easy to remove.
Richard
Old 07-26-2009, 07:46 PM   #17
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Richard,
This heat is brutal. Is your new A/C a 13.5k or 15k BTU model? Seems like yours does a great job cooling down your trailer. My Dometic is a 13.5k model and I have no idea how old is it, but it really doesn't cool the trailer down like yours. I may need to recharge it.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-26-2009, 07:52 PM   #18
2002 25' Safari
Dewey , Arizona
Images: 62
Mine is a 13.5 Carrier low profile with a heat strip. I bought it earlier this year.
Richard
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
What's in my backyard this morning??? tinbender Member Introductions 20 11-06-2010 07:34 PM
Ad Server bugs this morning?? Wabbiteer Forum Admin, News and Member Account Info 2 03-28-2008 08:20 AM
Off in the morning gowyn On The Road... 4 10-16-2007 06:48 PM
