Old 12-22-2012, 06:20 PM   #15
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Well, my install is almost done. In the process, I found out how they built Airstreams in 1978.
First thing down the assembly line was the furnace, dangling on a coat hanger off the chain. Then, everything was assembled around the furnace. This eliminates - trust me on this -the possibility that the furnace will accidentally fall out on the road.
Seriously, I thought the water heater was a biscuit, but it had nothing on disassembling the entire kitchen cabinet to get the furnace in and out. The only blessing in the project so far has been that the power exhaust and intake tubes did pretty much match exactly.
If you're contemplating doing this yourself, you will need:
  • A vast assortment of tools
  • A comfy environment
  • An extremely resilient sense of humor and...
  • A strong desire to enrich your vocabulary.
drboyd is online now   Reply With Quote
Old 12-22-2012, 07:02 PM   #16
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
No problem with the wood on mines
Old 12-23-2012, 08:01 AM   #17
drboyd's Avatar
1978 25' Tradewind
The installation instructions say that the NT30 is rated for zero clearance to combustibles on top and bottom. Thus, per the factory, putting it directly on wood should not pose a problem.
Old 02-24-2013, 08:00 PM   #18
1976 Argosy 26
Fair Oaks , California
In process of installing NT30 Suburban in my 76 Argosy. The old style furnace has a large and small opening for the intake and exhaust ports where as the new style has two large ones. What is the best course of action ? Do I enlarge the intake opening or is it o.k. to mount the intake flange from the inside . I see where some using the old cabinets but no mention is made of any modification for the larger intake pipe.
Argosy Heir is offline   Reply With Quote
heater installatioin
Suburban NT-22A furnace mickeymoose Furnaces, Heaters, Fireplaces & Air Conditioning 19 09-30-2017 06:53 PM
Replacing NT22A furnace with a NT30SP vhord Furnaces, Heaters, Fireplaces & Air Conditioning 1 02-24-2009 01:00 PM
Surburban NT 30K vs. NT30SP musketeer Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-28-2008 11:55 AM
Replacing the NT22a with an SF-20 Anyone done this Thealt Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-03-2008 11:18 PM
Best price for a new NT30SP wacnstac Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-21-2007 12:06 PM
