Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-10-2002, 01:46 PM   #1
74Tradewind
74Tradewind's Avatar
Profile:
Question Missing piece for Armstrong A/C?
Hi All,
Is there a piece or a plate or brace that connects from the frame of the A/C and extends forward to help hold down the front of the cover?
The front of the cover just sits on the roof and the first point of attachment is on the top of the A/C unit with just two screws followed by four screws around the fan. This seems rather flimsey and I don't want to loose the cover while traveling.
Ciao, Brian
74Tradewind is offline   Reply With Quote
Old 07-10-2002, 05:16 PM   #2
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
The Armstrong on my '77 Excella 500 has 4 screws in the top of the shroud. There are 2 toward the front and 2 toward the rear. There is no framework around the edge to hold the front or bottom edge of the shroud to the trailer.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Is A/C original? whistler Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-19-2004 05:32 AM
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 07:50 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 06:29 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 11:52 AM
Retrofitting Roof A/C 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-14-2003 05:54 PM
test
