Old 11-19-2015, 12:22 PM   #15
mapleton , Utah
Thanks for the very complete evaluation. I am deciding between this unit and the dickensen, love the looks of the cozy cabin.
tim
rumrunner is offline   Reply With Quote
Old 04-18-2017, 03:22 PM   #16
1975 31' Sovereign
Jacksonville , Florida
So where could a body find a kettle like that? Could one be had for love or money? (I'm good in the sack if you're not choosy about gender.) Darn, now I've got that "What would you do for a Klondike bar" jingle stuck in my head. Oh yes, kettle. So... kettle... where could a body find one like that, hmm?
Bluejay1981 is offline   Reply With Quote
Old 04-18-2017, 07:55 PM   #17
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Whale Tail Teapot
My English friend insists it's a teapot, not a kettle. I pinched and poked it out of a glob of porcelain clay. Fired it to 2300F.
Red Rose is Canadian tea. It's not the greatest, but I drink it in honor of the marquis chimps.
<iframe width="640" height="360" src="https://www.youtube.com/embed/prVRwXAWFeA" frameborder="0" allowfullscreen></iframe>
ALUMINUMINUM is offline   Reply With Quote
Old 11-06-2017, 01:44 PM   #18
1970 25' Caravanner
Incline Village , Nevada
Aluminuminum :
Diddo on all the compliments on install of that unit. Can you provide details of cost and where you purchased it from?
Jeremy9107 is offline   Reply With Quote
Old 11-06-2017, 02:14 PM   #19
1981 31' Excella II
New Market , Alabama
What is the BTU rating about 10,000? It has that antique look to it and it is simple. It looks like a good choice for a vintage trailer.
Perry
Old 11-06-2017, 03:15 PM   #20
Fort Davis , Texas
"It has never deployed its oxygen depletion safety shut-off."
Be careful with non-direct vent (use inside air for combustion) propane heaters with oxygen sensors. I live at 5,400 feet and most gas heaters with oxygen sensors don't work at this altitude. (The ambient air does not contain enough oxygen).
Pat
pdavitt is offline   Reply With Quote
Old 11-06-2017, 08:07 PM   #21
NO HUMBLE OPINION
There are a few sellers around $500… It's sold by Dickinson now, as part of their stove line-up. Before it was made by sig Marine in Canada. Long ago it was called Force 10. There's a Diesel version.
http://www.go2marine.com/product/831...at-heater.html
I've seen the advertised BTU vary... Original Canadian sig Marine rated at 5500, Dickinson rates it at 6500. I don't know why.
It's a good size and fit for the 68GT.
If I ever trail over the Rockies, I'll plot its performance along the way from Lake Michigan's 577' above sea level. I have not read where a Cozy Cabin was put to a high altitude test. I wonder if sailors on Lake Tahoe 6,225' use them? It will be good to discover its limits.
Old 11-06-2017, 10:16 PM   #22
2017 27' International
Sioux Falls , South Dakota
Dickinson P12000
About a month ago I installed a Dickinson P12000 bulkhead-mount heater in my 2017 International 27FB. I placed it on the wall by the fridge (after removing the TV, which I don't use), so that it faces the dinette. I tapped propane and 12 V power from the fridge's outside compartment.
I removed the end cushion from the couch, since nobody would want to sit right up against the heater. I mounted the heater quite low--the center of the window is only 18" above the couch's seat cushion, right at chest level--so I had to add a 10" stovepipe extension.
I like the P12000 very much. I have previous experience with Wave 3 (3,000 BTU) and Wave 6 (6,000 BTU) catalytic heaters. They're silent and efficient, but require opening a vent or window, which lets in cold air... and their heat output is extremely directional, so they basically just heat what they’re aimed at.
By contrast, the 5,500 BTU Dickinson P12000 has a small, quiet fan that draws only about half an amp, but does a very good job of spreading the heat around. And its coaxial stovepipe, with an inner exhaust pipe and an outer intake pipe, means I don't have to open a vent or window. The intake air is preheated as it travels down the pipe, so it's a very efficient system.
Drawbacks? Well, aside from eliminating the living room's TV, which I understand many folks may not want to do, I had to cut 3" holes in the ceiling and in the roof. That was a bit scary. (I used a hole saw to cut most of the way through, then finished with a handheld hacksaw blade.)
I found that I enjoyed sitting next to the heater on cold mornings, so I installed a small dimmable LED reading light on the wall above the stove.
As far as temperatures are concerned, the heater's window becomes hot enough to burn you (450° F. or more), but the rest of the unit remains touchable. The lower front panels and outer case are actually cool to the touch, and the upper grille is barely warm. Even the stovepipe is touchable, although not for very long--it runs about 110°-130°. (Remember, the outer stovepipe is carrying cool air from the outside.) No oxygen-depletion sensor is needed, since air is coming from outside the rig. I've used the heater at elevations as high as 7,000 feet without a problem.
The adjacent wall barely gets warm, and the couch cushion, which is only ten inches below the heater’s base, stays cool. The cardboard semicircle you see in the photo is a placeholder for a wooden one that I'll put there--not to protect the cushion, but as a convenient place to set drinks and snacks.
That's my experience, for what it's worth. The P12000 isn't cheap, but it works very well. And its all-stainless-steel construction should make it last a long time, as well as nicely complementing the brushed-silver Airstream look.
Paprika is offline   Reply With Quote
Old 11-07-2017, 07:54 AM   #23
1970 25' Caravanner
Heat in rear
Aluminuminum
How well does that distribute heat to the rear of the trailer? Assuming you have a bathroom and bedroom back there? Location seems optimal although now that you have been using it would you suggest any other mounting places?
Old 11-07-2017, 08:24 AM   #24
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Dickinson P1200 Propane Fireplace
We installed our fireplace last April. The fireplace is nice because it adds some nice ambiance. The flue is double walled and it is a direct vent. The combustion air comes down the outside chamber of the flue from outside and exhausts the combustion gases out the inside chamber of the flue.
It has a small, quiet fan that helps to circulate the air, but I installed a 12 volt fan on the bulkhead above the dinette to move the warm air throughout the coach. We installed ours above the cushion as there is enough clearance below, but if I was doing it again, I might remove the cushion so the view of the firebox is better. The fan in the fireplace and the Sirocco fan use a lot less 12v power than the furnace so help with boon docking.
ID:	298569   Click image for larger version
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 11-07-2017, 08:30 PM   #25
NO HUMBLE OPINION
In small sixties trailers like the GTs, Caravels, there was no duct-work, the original furnace blew directly into the cabin about mid-ship. There was no holding tank heat. No bedroom. The cabin length of the entire GT is 17', Caravel is 14' inside. Heat circulation for the Cozy Cabin relies on natural convection and whatever passive current stirring the human occupants create.. The Cozy Cabin has a small burner compared to gas stove-top. 6000BTU is 1750W.
As mounting places go, there are few to none in an Airstream. In my re-model, its placement only has a few cm of wiggle room so it doesn't interfere with the manufacturers clearances, microwave door, refrigerator door, overhead cabinet door, roof vent, and pocket door.
The 1200 Dickinson with fan should out-perform the Cozy Cabin.
ID:	298617   Click image for larger version
ID:	298619   Click image for larger version
Old 04-13-2018, 02:25 PM   #26
Mtmanor's Avatar
1967 22' Safari
1966 24' Tradewind
Columbus , Ohio
Backer cloud
Looks like it's living up to it's name. Looks very cozy.
Would you mind if I copy your design for the backer plate? The cloud design is perfect, simple and smart.
Also, off subject, but could you share your cooktop info? It's time I ordered one.
Thank you.
p.s. Your teapot is great. Love porcelain.
Mtmanor is offline   Reply With Quote
Old 04-13-2018, 07:02 PM   #27
NO HUMBLE OPINION
Thank you.
p.s. Your teapot is great. Love porcelain.”
The cabin heater has been successful for our little trailer. It works just fine. You're welcome to copy any aspect of whatever interests you.
The residential cooktop came from eBay. No problems with it. The cast iron burner top can be lashed down for travel with an elastic cord or removed.
https://www.ebay.com/p/Ramblewood-Gc....c100005.m1851
The Whale Tail Teapot was a good diversion.
http://www.airforums.com/forums/f483/whale-tail-teapot-116742.html
ID:	308661   Click image for larger version
SIG MARINE Cozy Cabin Solid Fuel Heater alexdubs Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-03-2014 09:39 PM
Dickinson Marine Newport propane heater/fireplace bgordon Furnaces, Heaters, Fireplaces & Air Conditioning 7 12-12-2012 02:02 PM
Marine solar point of use water heater Globie64 Water Heaters, Filters & Pumps 0 04-21-2011 01:19 PM
Interior Bulkhead RichardM General Interior Topics 0 08-14-2005 11:10 AM
Bulkhead Structural Value 69Ambassador General Interior Topics 24 03-21-2004 07:43 AM
