Old 07-29-2012, 03:56 PM   #1
1966 26' Overlander
Provo , Utah
Mach 3 stopped cooling
I'm a real newbie when it comes to the AC, but I'm pretty handy with most stuff--so I'm hoping I can fix this myself.
A few days ago, in 90+ weather, the AC just stopped cooling. Still blows air, just not cold. Any thoughts?
kylewbenson is offline   Reply With Quote
Old 07-29-2012, 04:19 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
You need 30 amp to run A/C. Any possibility you're on a 20 amp service?
  1. Reset all of your circuit breakers, can't hurt. On newer Airstreams you have to turn them OFF, then ON to reset.
  2. Turn off the A/C, then pull the filters off and clean them (a quick vacuum will help if they're impacted). Turn back on and try again.
  3. Turn off the A/C, pull the cover and look for loose or burned wires. Repair if found.
  4. Curse, call a pro. You've probably lost all of your coolant or blown the compressor.
How old is the A/C and is it still under warranty? I figure you get 10 years of steady use and you're on borrowed time.
Paula
