Old 05-31-2010, 02:48 AM   #1
AxelBruijnis's Avatar
1978 31' Sovereign
Gasselternijveen , drenthe
Send a message via AIM to AxelBruijnis
Lost AC shroud on highway, will it leak ?
Hi Guys..
during my most recent trip in strong wind, i lost the AC shroud , including some hardware ( some fan-blades , the radiator )
Since i am located in Europe, it will be hard to find a replacement 110 Volt AC quickly.
if i travel without the shroud in the rain.. .. will it leak ?
thank you for your opinions !
Axel
1978 Sovereign 31 Mid Bath
1969 Overlander 27
2000 dodge 2500 diesel
AxelBruijnis is offline   Reply With Quote
Old 05-31-2010, 05:01 AM   #2
SteveH's Avatar
Common Sense , Texas
Yes, the rain will come right in. Without the shroud, the A/C system is basically wide open to the elements. I had to replace mine this year also, but fortunately found it cracked before it actually blew off.
I would suggest you find some heavy duty sheet plastic and duct tape that over the system until you can get a replacement shroud.
Regards,
Steve
Old 05-31-2010, 05:21 AM   #3
Originally Posted by AxelBruijnis View Post
Hi Guys..
Axel
Axel.
The AC shroud for which coach?
Old 05-31-2010, 06:43 AM   #4
1978 31' Sovereign
Originally Posted by Inland RV Center, In View Post
Axel.
Andy,
For my 1986 excella 32 ft.
It was a coleman, i cleaned the shroud 2 days before losing it , it seemed OK then, and felt very attached to the rest of the trailer.
i am thinking about replacing it with a carrier low profile.
Axel
1969 Overlander 27
Old 05-31-2010, 08:46 AM   #5
Andy,
Axel
Axel.
That AC shroud is cosmetic. All RV AC's are "ugly" without a cover.
There cannot be a leak caused by the missing shroud.
The only leak you could have with that AC, is if it was loose in it's mounting, or if the gasket is bad.
A Carrier high or low profile, is an excellent choice, if you choose to replace the AC.
Go with a 15,000 BTU model.
air conditioning
The Beartooth Highway? ZoominC6 On The Road... 29 06-10-2013 05:49 AM
Alcan Highway Bert Gildart On The Road... 19 09-18-2009 09:34 AM
Highway 1 and brake chatter bevman Brakes & Brake Controllers 5 05-19-2008 12:31 PM
West Boondocking Gravenstein Highway walter1 Boondocking 0 10-12-2007 03:00 PM
