Old 12-31-2010, 12:12 PM   #1
Dan Clayton's Avatar
1956 22' Flying Cloud
West Linn , Oregon
Images: 14
Looking for part for furnace
Need the following furance part for my 1956 AS . This furance is the tube type, which is incased in a half moon reflector. The part I really need is the pilot light. I have two of them, and both of them the small tube is broke. One of them was working, but has now broke off.
I am looking for either the entire burner assembly, or just the pilot part. Can use the whole thing if you have one.
ID:	118305   Click image for larger version
Dan Clayton is offline   Reply With Quote
Old 12-31-2010, 12:27 PM   #2
Melody Ranch's Avatar
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Dan,
I am not sure...never am, but the burner and pilot look the same as in my 56 , Day & Night wall furnace. The same company made both types of furnace so maybe you can sub the parts.
Old 12-31-2010, 07:20 PM   #3
West Linn , Oregon
Images: 14
Was not sure if it was a Day or Night model, could not find any markings on it, the furance itself that is. I see the burner says General Control, and it does have a part number. I would not mind upgrading if I could find something that would fit in the same area, or happy to go with the old if I can locate one. Do you have, or have you had any contacts with anyone on the Day and Night parts? I was really disapointed when that tube broke, because the burner was working great. I am ready to cut the closet wall opening for the unit, but don't want to make the cut till I know for sure I can fix the unit.
Old 12-31-2010, 08:08 PM   #4
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I do not have any sources but am looking. Maybe this can help you out.....Dials pages are GREAT!
Restoration Topics - Panel-Ray Heaters
Old 01-02-2011, 08:16 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
The small tube is for the thermocouple.
You may find that a standard thermocouple will work, You can get them in any hardware store or home center, usually in the water heater parts section.
You might have to make a bracket to mount it, and do some experimenting to get it in the right spot. If you put it in the wrong spot the burner won't stay on. It doesn't need to be in the original location, just someplace where the pilot flame hits it.
Old 01-02-2011, 08:49 PM   #6
West Linn , Oregon
Images: 14
Great I will look into it. After I had to replace the pilot light,and found that it was not working then I could only get the burner to run with the safety button pushed in. As soon as you let go of the button it would go out. There must be a connection between the two. Before I could turn the knob over to burner on, and you could hear the gas flowing. After I put the second pilot light on, you could only hear the gas flowing in the burner when the safety button pushed in.
Old 01-02-2011, 10:11 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Jammer is right, see post 5.
When the thermocouple is properly heated by the pilot flame, it acts like holding the "safety button" in. When they fail, as soon as you release the "safety button" the pilot goes out.
This is a common failure in all types of gas appliances. I've had thermocouples fail in home heaters and water heaters as well as in RV stuff. They are not expensive and are easy to replace.
Once you have that working, you can address the biggest issue in an old furnace. Make sure that there is no way for combustion gasses to get into the coach. Old units often have holes rusted in the housings that can allow CO to infiltrate. Please check all this out carefully, as that is a very old furnace if it is original.
Vaughan
Old 01-03-2011, 06:26 AM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I want to echo that wsingfield said about checking the heater. The NT-22 in my Trade Wind seemed OK, but I had a buddy in the HVAC business to look at it (needed a sail switch). Upon checking he found a hole in the heat exchanger. It was not obvious to me but it was to him. It would have allowed combustion gases to mix with heated air and you know the potential tragedy that could cause. Make SURE you have the heat exchanger checked by someone who knows what they are doing.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-03-2011, 03:23 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Dan;
It looks like you need to replace the thermo couple. If you have and it won't stay lit, it may be because the end that goes into the gas valve is not pushed in far enough. The valve you have on your furnace is similar to the valve I have on the refer. Disconnect the thermocouple line from the valve; while you have it apart. Get some contact cleaner and a cotton swab; then clean the contact point down inside the hole where the thermocouple goes in. When you install the thermocouple be sure to push it in the hole as far as it will go, then tighten the nut to hold it in place.
Does thie burner assembly set inside a vertical cylinder about the size of a 2# coffee can?
Old 01-03-2011, 03:51 PM   #10
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
I replaced the thermocouple on my household water heater recently. In my research of that I discovered they are a standard design that has not changed format since the 50s, so a new one ($11 at the orange or blue places) should fit right in. Just ensure 1/2" of the tip is fully in the tip of the pilot flame. Do not kink the copper tube coming from the thermocouple - if you need to bend it, do so by bending it on a curved object at least 3" in diameter.
TX-16
Dave Park is offline   Reply With Quote
Old 01-08-2011, 06:50 PM   #11
West Linn , Oregon
Images: 14
My burner assemble is round and a little larger the the burner head. The whole furnace is in excellent condition with no holes. Everything was in perfect order until I found a hole in the pilot light tube. The pilot light has the tube built into it so it can't be replaced. Someone out there has to have one that there not using, by replacing the furnace with a new style. I want to keep this furance. I have had a couple and they work great!
Old 01-09-2011, 12:33 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Does the thermocouple go up inside that casting where the pilot light head is? Does the center of the pilot have a hole for the thermocouple to stick up inside of the pilot or is it just along side? There is no requirement that the new thermocouple has to go in the same place as the old one. It just has to be located so that the end of it is in the pilot flame.
Here is what I would do. Just below the pilot head there is a hole in the casting. I would fabricate a bracket to hold a new thermocouple in a position where the end of the thermocouple would be held in the pilot flame and attach that bracket using that hole. Cut the old line off of the old thermocouple and just leave the head of the old thermocouple where it is. Then screw the new thermocouple line into the gas valve where the old one was. Make sure to seat the end all the way down into the hole in the valve before you tighten the nut. If this doesn't make sense let me know and I'll try to do a better job of explaining it.
I have the same or a very similar furnace in my '69 Travel Queen truck camper, it's in excellent shape and works really well. The great thing is there is no noisy fan.
Old 01-09-2011, 07:32 PM   #13
West Linn , Oregon
Images: 14
There is no thermocouple in this unit. Pilot light runs and you manually turn the main burner off and on. I have added a couple of pictures which give a little more detail. The small gas line just runs up the center of the pilot housing. It has an air screw to adjust the amount of air running thru it. I would put a sparker on it replacing the pilot, but the burner won't run without the pilot running.
Old 01-09-2011, 08:48 PM   #14
West Linn , Oregon
Images: 14
Or is the thermocouple in side of the pilot tube as you suggested? I can't tell. I will pickup a thermocouple this next weekend and give it a try, sure won't hurt anything.
Thanks for the idea.
Old 01-10-2011, 08:31 AM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The pics didn't show up. I believe the small pipe in the first pic you posted, the broken one is a thermocouple. You are correct that the unit is manual burner on. But the pilot must be lit and the thermocouple must see the flame before the valve will open for the main burner. The pipe in the pic that goes up the left side is the pilot gas line, the main burner gas goes right up the center of the main burner I believe. See where the big hole in the side of the pipe is just below the main burner, I think that's where the air is mixed with the gas for the main burner. That screen around the pipe is the air shutter for the main burner. It may just be a knurled piece but it looks like a screen.
Old 01-10-2011, 11:41 AM   #16
1983 34' Excella
1967 24' Tradewind
Images: 32
I agree with Twinkie.
I think it will make more sense to you when you have a thermocouple in hand.
Vaughan
Old 01-10-2011, 05:45 PM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Hey Dan; Where is this air screw you mentioned in an earlier post?
The following is from your previous post.
((It has an air screw to adjust the amount of air running thru it. I would put a sparker on it replacing the pilot, but the burner won't run without the pilot running.))
I keep looking at your photo above and can't help but think that the thermocouple could be removed from the pilot housing.
Old 01-10-2011, 06:14 PM   #18
West Linn , Oregon
Images: 14
TG, The air screw is that round honey cone looking thing. Since I have two of these units and they are both not working at this time, I am going to see if I can get one of them apart. They looked as if they did not come apart, but hey they are also better then 50 years old. The tube with the small hat on it is press fitted into the mounting bracket, were it says Gereral Controls. That thermocouple may be just rusted in. I will let you know what the out come is. Thanks for all the insites. I always learn something about these trailers every week!
Old 01-10-2011, 06:26 PM   #19
Wise Elder
Jammer's Avatar
2010 30' Classic
Dan there is a thermocouple there built into the pilot light.
They don't do it that way any more.
You will want to make a little bracket to hold the new thermocouple unless it appears easy to disassemble the pilot burner without damaging it.
Old 01-10-2011, 10:44 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Dan: I agree with Jammer, Don't damage the body of the pilot assembly by trying to remove the old thermocouple. If you would happen to get it out and the new one doesn't fit tight you may have flame coming out the hole where the old thermocouple was and you will certainly mess up the gas to air mixture. Cut the old tube off at the base of the pilot assembly. Then fabricate a bracket as we've mentioned to hold the new one in place.
