Old 06-14-2009, 09:18 AM   #1
1972 31' Excella 500
Shelby , North Carolina
Smile Looking for Control Module-Coleman Delta TX
I have two coleman Delta TX 13.5kbtu A/C units on my 88 345 Motor home. I have swapped the control unit (switches and knobs on right hand side of A/C unit) from one AC to the other. The problem follows the control unit. Both AC units blow cold and were fine with the good module installed. The part of the module that does not work is that it won't turn on the compressor. All heat,variable fan, exhaust fan work fine.
If anyone has a module out of there old unit, I would like to get the module. If you know of someone that repairs them either. Please let me know if you have more ideas or modules.
Thanks!
1988 345 Motorhome
1972 31 Excella 500
DataMover is offline   Reply With Quote
Old 08-06-2009, 01:23 PM   #2
1977 31' Excella 500
portland , Tennessee
You dont have a inside shroud to sell do you?
netlace is offline   Reply With Quote
Old 08-06-2009, 02:48 PM   #3
I tried and failed to get one of these modules 5 years ago. The company informed me that the modules were obsolete, unobtainable, and non-repairable. A friend repaired his module by just spraying a load of WD40 into it. There is a fault-finding downloadable PDF which includes a series of suggestions if the compressor doesn't run, but everything else does:
SERVICE MANUAL FOR 6700, 7000, 8000 & 9000 SERIES AIR CONDITIONERS ..._The free ebook,office and pdf documents downloads
Good luck.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Replacing Coleman Delta TX 13500btu A/C tr674 Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-23-2014 08:50 PM
Replacement shroud for Coleman Delta TX a/c blackbird Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-03-2013 06:55 AM
Cruise control module bkahler Mechanics Corner - Engines, Transmission & More... 2 01-10-2009 07:16 PM
Coleman Delta TX - Repair? Ganglin Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-15-2007 04:06 AM
Hi Perf Module ALANSD Mechanics Corner - Engines, Transmission & More... 0 05-13-2002 07:03 AM
