Old 05-29-2007, 11:03 AM   #15
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Thermostat Control Closeup
Just following up on our thermostat issue.
Here is a close up...
So if I understand this correctly, the arc slider at '1' allows you to adjust the switching differential, which would
be the temperature range before the unit cycles on/off. Seems to me this can also be controlled by adjusting the
screw at '2'.
Can someone clearify the usage of these two controls? I'm essentially trying to shorten the on/off cycle so we don't'
suffer through too cold/too hot cycles.
Too bad this darn thing is in the bathroom of all places!
campadk is offline   Reply With Quote
Old 05-29-2007, 11:23 AM   #16
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Adjustment #2 is how you convert a precise device into an accurate one. It calibrates the temp arm to read correctly.
One thing to check when you have short cycle times is for obstruction of the ducting or intake or a slow fan. Any of these will casue the firebox to overheat and shut-off prematurely.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-29-2007, 12:18 PM   #17
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
I'm glad I asked this question. I don't seem to have adjustment #1 on my thermometer, so can I use #2 which I do have?
wacnstac is offline   Reply With Quote
Old 05-29-2007, 12:23 PM   #18
Excella CM's Avatar
Venice , California
I'm pretty sure you'll need a different thermostat.
Old 05-29-2007, 02:45 PM   #19
Originally Posted by campadk
can someone clearify the usage of these two controls
Ignore 2. As stated above, I suspect it just enables the dial to show a more accurate number for the ambient temperature. Switch the 12v power off (batteries, 110v supply and tow vehicle umbilical). [I confess I don't bother to turn off the 12volt supplies.] With a finger, slide 1 across to the other end of the arc and see how the switching differential changes in practice when you start up the furnace after reconnecting the 12v. Then adjust it back a little at a time until it achieves your desired comfort level. I suspect 1. puts a variable resistance in the circuit.
This is a crude device. Changing to a digital thermostat is a huge improvement for very little outlay in time and money.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Suburban Furnace recall !!! NewStreamer Furnaces, Heaters, Fireplaces & Air Conditioning 34 11-26-2015 03:29 PM
New Furnace Needed 74SovereignInt. Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-24-2002 12:03 AM
Too hot but had a good time suekozin On The Road... 11 07-20-2002 02:45 AM
First Time Buyers Sheri On The Road... 5 07-08-2002 08:09 AM
Deactivated Furnace will Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-22-2002 08:19 PM
