Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-25-2009, 01:04 PM   #1
Profile:  1967 26' Overlander
Winston Salem , North Carolina
Images: 101
Location in ceiling for AC in a 67?
Hi Everyone,
Where exactly do you cut the 14x14 hole for an AC in a unit?
This unit has no ac.
67 Overlander side double.
AS told me yesterday the wire is 124 inches from the first bow/rib.
Is that the exact location for the AC?
I have seen other 67's and the ac unit is over the axles in the bedroom.
I do know, the ac is not mounted in a ceiling vent
I will have to beef up the ceiling for support.
I am leaning towards the Carrier 15k unit with a heat strip.
Thanks for your help in advance
Greg
Winston Salem, NC
WBCCI 5218, Piedmont NC Unit 161
1967 Overlander International.
FTC 15771
1979 Avion 30ft rear bath
Silverwanabe is online now   Reply With Quote
Old 06-25-2009, 02:15 PM   #2
Commercial Vendor
Profile:  Corona , California
Originally Posted by Silverwanabe View Post
Hi Everyone,
That dimension is on the "nose."
Make sure you beef up the roof before you install any AC at that location.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 07-03-2009, 12:36 PM   #3
Images: 101
I have cut the hole in the ceiling for the new AC.
(I have not trimmed it exactly 14 x14 yet)
There are two wires located in this area.
Which one do I use??
Why 2 wires?
Both are Kaiser Aluminum .
One has a bigger diameter and there is one like it in the trunk area not connected the the breaker box.
Also, there are two ribs running parallel to the new hole in the ceiling, a few inches from each side, running fore and aft.
I am assuming this is where the AC support frame ties into the structure for support.
Suggestions are welcomed.
Enclosed are 4 pics.
ID:	83336   Click image for larger version
ID:	83338   Click image for larger version
Greg
Winston Salem, NC
FTC 15771
Old 07-03-2009, 12:54 PM   #4
Commercial Vendor
Why 2 wires?
The AC's that Airstream used in 1967, did not require roof supports, since it became part of the roof.
Adding a new AC today, will require 2 horizontal stringers that tie into the fore and aft main bows. Additionall, two other sections of supprts must be added between the 2 stringers, making the 14 x 14 inch hole in the roof secure. It not done that way, a new AC will cave the roof in.
The largest wire is for the power to the AC. It terminates near the breaker panel, and must be wired into that panel, using a separate circuit breaker rated at 20 amps, no more and no less.
The smaller wire, is for the thermostat wires. The other end of that wire should be in the rooflocker on the road side, and behind the bulkhead.
The 2 stringers I mentioned must be added in addition to the two that you see.
Andy Rogozinski
Inland RV Center
Corona, CA
Ceiling height Fish36991 Airstream Trailer Forums 2 09-06-2006 09:31 AM
Ceiling? balrgn General Interior Topics 8 10-22-2004 06:19 PM
ceiling liner silverbullet96 General Interior Topics 13 11-28-2003 01:39 PM
Ceiling Fan? Fun-Lovin General Interior Topics 6 08-20-2003 09:44 AM
ceiling fan Cat Roof Vents, Skylights & Fans 0 10-06-2002 04:34 AM
