Old 06-08-2011, 04:13 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Latest Dometic CCC
I see that new production Airstreams have started shipping with a new Dometic CCC (thermostat).
Does anyone know whether this is better than the old CCC operationally or is it just a cosmetic change?
Old 06-08-2011, 04:42 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's different. I actually had to RTFM to learn how to make it do what I wanted it to do.
Old 10-26-2011, 06:31 AM   #3
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Along the same lines, I stopped at Out Of Doors Mart in Colfax, NC, to pick up a replacement thermostat for our 1999 Excella. The parts guy showed me one which looked similar to mine, but had a ZONE control under Mode, Fan, Up, and Down. Concerned that it might not plug-and-play we asked the resident technician. He said it would not work without replacing a major board in the Dometic Penquin, at which point I backed down.
QUESTION: can someone point me to a source for a simple replacement CCC for my old Excella?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 10-26-2011, 12:18 PM   #4
Member Slide Out Society
2004 28' Safari S/O
Zavalla , Texas Airstream Harbor
I've got a new one in the box I bought at International in Madison as a spare for my '97 Limited. Hooked it up to make sure it worked (it did) and have since sold the trailer. PM me if you're interested
Rockwell
Rockwell is offline   Reply With Quote
Old 10-26-2011, 01:29 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
The 4-button CCC is NOT COMPATIBLE with the newer 5-button CCC. It IS necessary to replace the relay board in the upper unit to enable the A/C to work with the 5-button model. Not really a big deal though..........i've upgraded about 15 of these units in the past few years to work with the 5-button CCCs.
I have a call into Dometic about compatibility of the 5-button CCC with the new round CCC....haven't heard back yet.
Old 10-26-2011, 02:06 PM   #6
lewster's Avatar
As I suspected based on Dometic's latest protocalls, the new round CCC is also not compatible with the existing 5-button CCC. They still have a good number of 5-button CCCs in stock, but as before, any upgrade to the new model CCC will require upgrading the relay board as well.
Old 10-26-2011, 03:08 PM   #7
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Maybe I should carry a spare 5~button CCC....what does a 5~button CCC cost Lew?
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 10-26-2011, 07:21 PM   #8
lewster's Avatar
IIRC, they are under $75. I'll check with Dometic tomorrow. You can be sure (after the 4-button to 5-button change-over debacle) that I will be laying in a large supply of the 5-button units.
I must say, however, that the 5-button units are far more reliable than the 4-button units. I have not replaced many in the last 6 years.
Old 10-26-2011, 07:29 PM   #9
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Apologies for this rookie question.... What does CCC stand for?
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 10-27-2011, 06:15 AM   #10
lewster's Avatar
Comfort Control Center
Old 10-27-2011, 06:28 AM   #11
Images: 59
The original units were Comfort Contol Centers. I think the 5 button models are Climate Command Consoles.
(I just made that up)
Old 10-28-2011, 12:29 AM   #12
Scott J-24's Avatar
Thanks.... Some times I suffer from TLA syndrome.
WBCCI #1215
Air #54601
Old 10-28-2011, 12:32 AM   #13
Scott J-24's Avatar
Oops.... TLA = three letter acronyms
WBCCI #1215
Air #54601
Old 10-28-2011, 12:01 PM   #14
2011 31' Classic
Yes, I worked in Washington, DC for years and they ALL suffer from TLA. There's AIA (American Institute of Architects), and CSI (Construction Specification Institute, not what you first thought), and DAM (Mother's Against Dyslexia).
Dometic Penguin or Coleman Polar Cub for 1967 Caravel?? vonzellen Furnaces, Heaters, Fireplaces & Air Conditioning 20 08-13-2011 06:10 AM
2010 Dometic A/C hansenk Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-04-2011 08:33 PM
Anyone need fridge parts from old Dometic '76 sweetsilver Refrigerators 4 06-24-2011 09:41 PM
Great Price on New Dometic Fridge RM2510 txstreamer Refrigerators 5 05-07-2011 06:26 PM
Dometic RM2804 owner's manual Jim Lee Refrigerators 2 04-10-2011 12:25 PM
