Old 07-11-2011, 06:20 PM   #29
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by withidl
...Additionally, while servicing the A/C filters I discovered two problems with the OEM installation:
∑ The A/C venting of cool air was somewhat mixing with the warm air being drawn in through the filters due to gaps in the installation (quality of OEM installation). I used some aluminum duct tape to seal the gaps.
∑ The foam backed vinyl ceiling material (on the Classic Limited) which is pressed down by the A/C cover had much excess that was hanging down inside the cover where the rear air was venting and was obstructing the air flow from those vents (quality of OEM installation). I corrected this by cutting back the excess vinyl.
I noticed the same thing this weekend with the excess vinyl partially obstructing air flow. I plan to trim the excess also, and will look to see if I have the same gaps you described. Good points!
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 07-11-2011, 07:08 PM   #30
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
No, it is not. We have panos on each end and that makes a big difference. We put Reflectix on all the bedroom windows and that helps a bit. We also use it on the skylight and fans when they are not in use. We keep the curtains and blinds closed too. But the insulation doesn't do much and the A/C unit is not big enough.
The awning helps, but you can't leave it because a windstorm might come along and it is not a very good idea to drive with it out either.
Driving in 100˚ temps turns the trailer into a furnace. Cars have had flow through ventilation for decades, but Airstream has not thought about that. The vents would probably leak anyway. It would help keep some of the heat down when traveling.
We try to stay away from hot places in summer, but that is not always possible. We'll be going to Pueblo, Colo., tomorrow where it is supposed to be in the mid-90's and the A/C will be running constantly.
Bob, thanks for the tip about setting the thermostat at 60˚ to get more out of the A/C. We'll try that tomorrow.
Gene
Old 07-11-2011, 07:21 PM   #31
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Re dust intrusion: I was at the Fantastic Vent factory a couple of weeks ago and this topic came up. Their head tech suggested that on dirt and gravel roads, which are typically traversed at realtively low speed, one ought to turn on the Fantastic Vent blowing IN, but with all windows closed ... that way, the fan takes relatively "clean" air from up top of the trailer and uses it to pressurize the trailer, significantly reducing dust infiltration from lower down. Haven't tried it yet, but this makes sense. I suspect that at higher speeds, the low pressure area aft the open vent flap would compete with the fan, reducing inflow a lot, and so this regime wouldn't work as well.
On hot travel days, I just leave the rear vent (it's covered with a Maxxair Vent cover) fully open, and it seems to remove a lot of the heat - the interior is typically about on a par with the outside temp, within three or four degrees when I stop. A lot of comfort is just moving air ... when I hit a rest stop, with the Fantastic Vent blowing IN on me and a Fantastic Fan also blowing at me as I nap or eat lunch, etc., I can be comfortable in temps of up to about 95 without A.C. But if I have to work or get out of the airflow, then I start to melt and want shore power and A.C.!!
AirsDream is offline   Reply With Quote
Old 07-11-2011, 08:17 PM   #32
lylesgl's Avatar
2007 27' Safari FB SE
Springfield , Virginia
My first Airstream was a 2005 25' Safari with the vinyl ceiling and fabric lined walls and an 11,000 BTU a/c. It seemed to cool better than my current 2007, 27FB Safari SE, that sports the 15,000BTU a/c. I think it has to do with the 27FB having the interior aluminum walls; the 25' safari with the fabric lined walls and vinyl ceiling most likely had a better "R" factor.
lylesgl is offline   Reply With Quote
Old 07-11-2011, 08:19 PM   #33
2011 27' FB Flying Cloud
Bradenton and Saluda , Florida & North Carolina
27FB Hot Weather Camping
Just got back from a 1.5 month journey with the final week and a half in 100 degree weather. Just like others, I have pana windows on both ends, and have not only put reflective automotive sunscreens, but also replaced the AS curtains with blackout lined curtains. This has dramatically reduced the heat factor.
Also went to Walmart and invested in the little fans that I could clip on to the bathroom door to direct air to the front bedroom or other areas that require more air. At the hottest period of day the front of the trailer would get a little warmer, I just turned on the fan, and adjusted the end grill of the AC pointed down a notch on the opposite end. This directed more air to the front that needed the most ventilation and it worked great. Trailer was comfortable and sleeping was equally so.
The worst part was dealing with over 300 other campers at this campground that were running every appliance they could and kept blowing the main breakers. After they figured out they were creating the problem, the power was more reliable. However, they all figured they needed to have a raging fire going outside each of their trailers - then all went inside to stay cool Still can't figure out this one, and choked on the smoke being sucked in through the vents, but luckily that was brief.
Happy camping for the rest of the Summer!
Nan
ncbambi is offline   Reply With Quote
Old 07-11-2011, 10:20 PM   #34
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by AirsDream
... one ought to turn on the Fantastic Vent blowing IN...
Has Fantastic Fan changed something? My old trailer had Fantastic Fans with a 3 position switch: In-Off-Out. Those that came installed on my '08 Classic have a simple On-Off switch; they only blow out.
AIR 47751
Old 07-11-2011, 10:32 PM   #35
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
According to the Fantastic Fan site, all units are three speed: FanTastic Vent - Products
Bill
Just my personal opinion
Old 07-12-2011, 05:51 AM   #36
richinny's Avatar
2011 34' Classic
i believe 'code' now requires factory installed fans to only blow out. if you call Fan-tastic they can help you.
Ricky
Old 07-12-2011, 06:03 AM   #37
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Gene,
Remember also that the lower the fan speed the colder the air will be out the vents. Thats where the aux fan comes comes in handy, once the interior has cooled down it can spread that cool air around.
Did a little test yesterday. Interior temp was 94. Turned on AC set at 60/Auto, was down to 74 within 45 min.
After 1 1/2 hr set thermo to 69, int temp stays at 72 with AC cycling normally and fan running at the lower speed. Still on, will check it several times today.
POI....(you know about this), humidity 74%
FF Model 8000 3 speed, out only.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-12-2011, 08:37 AM   #38
Goal15's Avatar
Dallas , Texas
I could read the manual but . . .
So Bob? In my 2006 Safari 23, I have a thermostat above the lav sink. My AC unit in the ceiling has high med and lo cool on one set of controls (as well as what appears to be fan only settings) and on the other set it has dial for cooler or warmer.
Is my thermostat on the wall connected to the AC unit also, or do I just have manual controls? For some reason I thought probably the thermostat was only for the furnace, a place where I haven't had occasion to go yet given the record temperatures we have had here pretty much ever since we got the AS in April.
Goal15 is offline   Reply With Quote
Old 07-12-2011, 08:53 AM   #39
Master of Universe
Gene's Avatar
Our fans only exhaust. Fantastic Fan will send you a 3 way switch if you call them. You need to have the model number.
Gene
Old 07-12-2011, 09:01 AM   #40
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
4th of July in Texas
We driveway camped in our '66 model 22ft Safari for four days during the weekend of the 4th as our house air conditioner had failed. The trailer stayed in the 20C (68F) area at night and rose to around 23C (73F) during the 100 to 102 degree afternoons. Carrier Low Profile 15,000 BTU was set to Low Cool all this time, and the thermostat switch was not all the way toward Low.
Our choice of the 15,000 BTU unit on a small trailer was intended for just these conditions, and it performed well IMO.
Old 07-12-2011, 09:17 AM   #41
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Gene
At a rally in Georgia, FF was running a special on the 3 way switch. $20 for switch and installation. Between the small size and the mouse fur, the Bambi really holds heat well. Being able to reverse the air flow works really well for us. I installed a screen in the rear window (er, escape hatch), and the fan helps pull air across the bed on those cool evenings.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 07-12-2011, 09:50 AM   #42
Sorry..... the ASS syndrome struck me, the ass between you and me.
I was not taking into consideration that all systems are not controlled in the same way.....my bad.
The pictured unit controls the furnace and AC, along with the AC fan when the AC is off. It is mounted on the outside Fridge compartment wall, not the best place, thus the difference in setting and actual inside temp.
I have a thermo control in the rear bedroom that controls just the rear FF.
Our AC has been on since yesterday morning, (13000btu), photo's taken 11am today. The unit is still cycling regularly with the fan coming on @ low speed.
ID:	134580   Click image for larger version
PFC
RLC
need air conditioner ally 1966 Overlander 2 07-02-2011 09:54 PM
Air conditioner went south... Bing-Bing Furnaces, Heaters, Fireplaces & Air Conditioning 12 06-16-2011 06:14 PM
Old air conditioner removed... Steps for new installation Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-14-2011 03:25 AM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
Air conditioner wattage ubuckster Furnaces, Heaters, Fireplaces & Air Conditioning 12 02-25-2011 12:53 PM
