Old 11-15-2009, 09:44 AM   #1
Lothlorian's Avatar
Loganville , Georgia
Is this the correct replacement furnace?
Furnace
Suburban Furnace - NT30SP, 30,000 BTU, compact and lightweight; efficient powerful and versatile. Gasket sealed vent assemblies with energy-saving solid state electronic ignition. Steel gas manifolds and sealed forced-draft combustion; chrome-plated vent caps
Old Furnace in my 73 Overlander
is a NT32A Suburban
30,000 BTU
Code GXF
I want to make sure before I buy it that I am getting the correct
Furnace.
What do you think? Is the NT30Sp the correct replacement?
I want to order today.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 11-15-2009, 10:52 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
You can call the factory in Tennessee and talk with customer service. I had two conversations with them concerning the proper replacement for the NT-22 in my Trade Wind. Both times the service guys were very knowledgeable and extremely nice. The phone number listed on their web site is Phone: (423) 775-2131.
FYI, because they don't make a direct replacement for the NT-22 and because we like to boondock, I decided go with and Olympic cat. heater.
Old 11-16-2009, 03:52 AM   #3
Lothlorian's Avatar
I ordered the furnace. After looking on and off since I bought the trailer I found one for $430.00 not including shipping. That was the best deal I found. It will be shipped out today and hopefully I can install it next weekend. What I like about this forum is I found about three very good threads on removing the old furnace and installing the new. Step by step instructions with pictures.
Brian
Brian & Adrienne
Old 11-16-2009, 06:43 AM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
It should work. Remember, the outer housing might not have to come out; check first, as it's a bear-cat to remove if you don't have to.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Help, replacement furnace? knjobrien5 Furnaces, Heaters, Fireplaces & Air Conditioning 22 04-18-2018 01:23 PM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 23 11-28-2011 05:28 PM
Furnace replacement...again walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 16 12-22-2004 06:53 AM
Furnace Replacement RiskIt Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-16-2004 01:50 AM
furnace replacement joecj76 Furnaces, Heaters, Fireplaces & Air Conditioning 4 02-18-2004 10:38 AM
