Old 09-14-2011, 06:51 PM   #1
1981 31' Excella II
New Market , Alabama
Is there a drain for the AC?
I thought I read somewhere about a drain for the AC unit. Does this exist and if so would it be in a mote under the unit or does the AC unit drain pan feed directly into this drain some how?
Perry
Old 09-14-2011, 06:56 PM   #2
SteveH's Avatar
Common Sense , Texas
On at least the newer models, there is a drain tube in the ceiling/wall of the trailer and it exits at the bottom, draining the water on the ground.
Regards,
Steve
Old 09-14-2011, 06:58 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
True of the older models too. That's exactly how our '72 drains.
Old 09-14-2011, 06:59 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There's been a drain tube in most models since about the mid 1960's or so. Now, whether your aftermarket a/c will hook up to it is another question.
Old 09-14-2011, 07:14 PM   #5
1981 31' Excella II
Yes but where is the drain and how do I clean it out. I am sure it is there but how do I get to it to clean it. I am going to replace the shroud so this is the perfect time to do it. I believe the unit is the original 1981 Coleman unit. A Mach 3 it is called.
Perry
Old 09-14-2011, 07:27 PM   #6
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Perry,
The AC drain on my '72 exits in the street side wheel well. When I was replacing the rear floor, I found that the tube had shrunk and was no longer protruding through the wheel well.
http://www.airforums.com/forums/f36/...tml#post945535
Lance
Top is offline   Reply With Quote
Old 09-14-2011, 07:32 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I know it can be done from the top, should be able to find it with the shroud off, 'bout a 3/8" black tube, but all I do is set the compressor regulator at 20psi and blow thru the drain at the outlet under the streetside middle. Usually at spring get ready and mid-season.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-14-2011, 07:52 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
As an aside...although it's not a huge big deal, I just hate to see water from the AC condensation dripping on the tire... so I bought a 2' length of clear plastic hose that slips over the drain tube so I can direct the drip away from the tire. I covered the end of the tube with a small piece of an old nylon stocking and secured it with a hose camp so no critters can crawl up inside it. I periodically flush and clean that hose out because over time the nylon accumulates scum, etc.
Name:	AC Condensation Drain_01_Sm.jpg
ID:	140212   Click image for larger version
Name:	AC Condensation Drain_02_Sm.jpg
TB & Greg and Abbey Schnauzer
#3954
Old 09-20-2011, 03:22 PM   #9
1981 31' Excella II
Anyone have a photo of where it comes out on top? I know mine is not working. I am going to be up there anyway I thought I would take a look at the top end of the tube so I know that is at least hooked up.
Perry
Old 09-20-2011, 04:05 PM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Perry
The drain line is between the inner and outer skins. This is how it looked on my original Armstrong unit.
Richard
Old 09-20-2011, 04:07 PM   #11
1981 31' Excella II
Ok cool so I can access it from the inside if I take the inside stuff off. That helps a lot.
Perry
Old 11-13-2011, 02:34 PM   #12
la nomade's Avatar
2018 22' Sport
stanfordville , New York
my drain did not work anymore,every time i turned on the ac it would start dripping inside,,did not want to take everything apart so i put in a new plastic pipe,re rooted it towards the door,over the sink and down( in between the wall)and since it works just fine and drains very well...it is sort of a home remedy...professionals would probably raise a eyebrow!!!!
la nomade is offline   Reply With Quote
Old 11-13-2011, 03:24 PM   #13
Ottawa , ON
Of course, this has happened before, and to many members. I like the contents of this thread, and in particular, post #10.
Your mileage may vary...
Old 11-13-2011, 04:55 PM   #14
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by la nomade
my drain did not work anymore,every time i turned on the ac it would start dripping inside...
It is not uncommon for certain insects to find one end or the other of that tube and make it their home. If you can get to either end and poke a suitable probe into the tube, you may break loose the clog and then as previously suggested, use some low pressure air to blow it out.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Freeing up water drain valve ashe Plumbing - Systems & Fixtures 8 09-10-2011 09:43 PM
Need Drain Hose Diameter for Penguin ASAP BrockLives Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-04-2011 05:59 PM
Fresh water drain AirEPotter 2011 - 2015 International 11 05-04-2011 02:34 PM
Carrier Normal Profile - Add Drain Line vhariable Furnaces, Heaters, Fireplaces & Air Conditioning 7 05-01-2011 01:51 PM
No Drain Tube bwaysteve Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-18-2011 03:59 PM
