Old 06-15-2015, 07:20 AM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Everyone has different temp/humidity tolerance levels. I am comfortable at 78-80 degrees F. Anything lower and I start getting too cool, higher and I am warm. My personal issue is high humidity. The older I get the more high humidity levels drain me. I made Reflectix interior panels for all windows and overhead vents. I use them on the sunny side to block the sun and keep the cool or heat in as necessary. With an outside temp of 100 degrees F my single AC unit has no problem getting the interior down to 70. The AC unit is just over a year old and works very well as AC or heater for my 23 foot Safari.
MICHAEL
Old 06-15-2015, 10:46 AM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
We had a 28' sob with one a/c. It worked OK, but I'm glad I have 2 a/c units now.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-15-2015, 12:16 PM   #17
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Seems like my experience is normal, so I have trouble understanding how Rich can cooldown with 1 AC in Florida in 3 hours. I do not want to go tearing things apart looking for ways to retape and insulate if I cannot expect much better results. Perhaps Airstream would not have moved to a 2 AC option if people did not like the performance with 1 AC in very hot climate conditions. Sure, we are spoiled but that is why we have an Airstream instead of a tent.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-15-2015, 12:48 PM   #18
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
We avoid really hot weather when we can. On our 25' we can close the sliding door between the living area and the rear bedroom and keep all the cold air up front. We close off the bathroom. The biggest limitation is that we can not run the microwave and the air conditioner at the same time so sometimes we just eat cold stuff out of the fridge. Awnings out all around helps some. Any way you can shade it helps. A couple of spray downs with water on the top and sunny side if you are in a place that you can get away with that. If you are pulling it will be hot when you stop. Turn on the air and go find a place to eat. If you stay still for a day or so it seems better to keep the air running and keep it cool all the time.
Old 06-15-2015, 01:08 PM   #19
2011 30' Flying Cloud
Greenback , Tennessee
It can be a hot world out there with one A.C.
My first AS was a 25' Safari (2006) with one A.C. When we got to the Rockies it was wonderful, but from Nashville to the mountains, it sucked! We first got the full ZipDee package and it helped some, but just not enough. We then got a big roll of the aluminized bubble wrap, cut it to size to fit all the windows and kept it in place while moving. That also helped some, as the trailer didn't heat up as much during the day. I had it checked by a couple of people and it was cooling as efficiently as it was designed to do. We finally decided that summer in the south or the midwest is not the place to be in an AS with one A.C.
We recently acquired a 2011 FC 30 with two A.C.s and I am cautiously optimistic. We leave East Tennessee in early July, heading once more for the Rockies. We have at least three stops before we reach the mountains, so I will have a better feel for things then.
Gneiss Guy is offline   Reply With Quote
Old 06-15-2015, 01:27 PM   #20
lsbrodsky's Avatar
I should have mentioned that we found that we absolutely must have a fan inside blowing from rear to front to equalize the temperature, otherwise the bedroom area(front) is much warmer than the rear. The overhead unit blows to the rear. I know ducted air should solve that issue but I cannot believe that 1 AC would do the job in a 95 degree trailer, even with ducted.
I also found out that leaving the AC running during the day at a reasonable temp allows the unit to keep up and cycle.
If I am on a multiday driving trip, I do not disconnect so the option to go find a cool restaurant is out. So, it seems summer camping in the South/Midwest is indeed another compromise. I already committed to an August rally but next year I may go back to my store it in the summer routine.
Larry
Old 06-15-2015, 01:28 PM   #21
AWCHIEF's Avatar
Images: 33
Larry
I have no trouble understanding it at all. On the Mississippi a Gulf Coast, In 90 degrees and 80% humidity weather my trailer easily cools to 70 in less than two hours sitting in full sun. I timed it today just to see. It is currently 94 outside and keeping 70 inside. Of course it is a relatively new AC, less than one year old.
MICHAEL
Old 06-15-2015, 01:45 PM   #22
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Here in montana and wyoming, most of the time we don't use the ac,today it is 65 degrees, humidity around 68....
Old 06-15-2015, 03:30 PM   #23
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Well, in this back and forth discussion I can only state what happens. Some state that you cannot keep a 25' Airstream cool with one AC unit- I can and with an 11K BTU unit in FL, in the nineties and high humidity.
I know this is an offshoot but we have a backup 10K BTU Fedders window unit AC that we keep as hurricane backup to run on the generator to cool the master bedroom suite of the house during power outages. That unit will cool that area down and keep it cool- even during the muggy aftermath of a storm. The room is on the southwest corner of the house. The room volume is large- 12 foot ceilings, 17x15 bedroom with no door adjoining bath area about the same size- a large space much larger than my trailer and certainly more volume. It is true that there are differences but it makes a point about size of unit and volume of area to be cooled. There is no way a 10K unit meets the calculation to cool such an area, even with the best of insulation but it works.
I admit I am a geek at heart. I have actually calculated for AC size on my Airstream model and it comes to just over 10K with three people inside. The calculation is easy to find online and it encompasses if there is a stove, window area, insulation, room volume, orientation of dwelling, etc. When I calculated, I used the least insulation and the worst orientation- ends at East/West sun baking a side long way. I DID use my exact window area. The point? The AC is big enough for the close to 150 sq ft. 6.5' ceiling space. Haines AC where we have purchased three home AC units from are highly rated in our area. They told us each time when we get to "what size" the discussion piece leads to "better to go smaller than too big." Our last purchase that replaced the original system of the current home was smaller than the original. The reason is the humidity- it has to draw it out BEFORE cooling it down to cycle. Bigger units will cool faster but then leave it damp- too big.
Swamp coolers are better in dry hot regions than AC. There are other differences as well. All Dometic units prior to 2010 and most brands used R22 refrigerant. In 2010 Dometic changed their compressor and systems to work with 410A. Look over this, check out the conclusion. This is one of many such evidences of the change to weaker all in the name of environmental protection.
http://fire.nist.gov/bfrlpubs/build02/PDF/b02186.pdf
You lucky dog. Let's all head for Montana!
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-15-2015, 03:58 PM   #24
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
We have a 1990 Excel 29' with a 13.5 AC and it does get warm in the summer, even in the North Georgia mtns in July-August. We travel with box fans, and we have a small rotating fan that sits on a shelf in the rear bedroom, and if all of this just doesn't do it, we make up the front couch into a double bed, and freeze directly under the ceiling AC outlet. So we do carry blankets, even in the summer. We would hate to give up the rear Fantastic Fan ceiling vent, even for a second AC unit.
dcasr is offline   Reply With Quote
Old 06-15-2015, 04:22 PM   #25
2006 25' Safari
Images: 8
Circulation was an issue for me until I got the new air box. The old style box directed all the air to the back or front so that at night sleepers froze with cold air drafts blowing. The new style, I lost the heat element, allows me to turn off the fore/aft vent and blow it to the sides and straight down. It made a huge difference. Also, if I run the fan on low, the rear of the trailer gets warmer. I can close the front vent and it balances the air. In high humidity I have learned to keep the fan on high to keep the air flowing in the unit and from freezing up.
We've Had Another Awesome Summer... TRfour Off Topic Forum 4 10-10-2010 09:57 PM
Another trip, another repair swanky Classic Motorhomes 6 07-07-2009 02:24 PM
Reasonable Compromise for TV? Streamer1 Tow Vehicles 16 09-15-2006 08:45 PM
And we thought we were bored (dreaming of summer camping...) Xray Our Community 0 04-08-2004 12:58 PM
