Old 06-10-2011, 07:35 AM   #1
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is it a filter?
I removed the interior shroud from the original Armstrong AC; just to see what things look like. I can see the squirrel cage blower thru one rectangular shaped hole. There is another rectangular shaped hole toward the condenser end of the unit. When I look up inside, there is some kind of material; can't tell if it is a filter or just sound deadening material. Unfortunately the PO replaced the original exterior shroud with one he fabricated and riveted it down to the roof. I don't really want to remove it if this is not a filter that needs to be maintained. The AC unit works fine.
Moen Pure Touch Classic filter Denis4x4 Sinks, Showers & Toilets 7 06-03-2011 11:23 PM
Fuel Filter (s) 1995 Cutter LE Ford F53 Chassis BarnacleBill Land Yacht/Legacy Motorhomes 2 04-12-2011 08:33 AM
2008 Safari 25FB - Water Filter Location JDEJV Water Heaters, Filters & Pumps 5 04-10-2011 06:08 PM
Kitchen Water Filter??? pappy19 On The Road... 1 02-13-2011 04:54 PM
Water Filter Sump Replacement elzavb Water Heaters, Filters & Pumps 1 01-11-2011 05:12 PM
