Old 06-21-2013, 12:27 AM   #1
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
International Furnace vs Catalytic Heater
Greetings:
We posted earlier today our gray tanks were going in and the original ducting from our International Furnace was in the way. We considered modifying the ducting then read the older post where Andy strongly recommends not using the original furnace. We are now considering taking it out entirely and just using a Catalytic Heater. Two Questions:
Q: is a catalytic heater (i.e. Wave 6) enough to heat a 24 ft?
Q: if we remove old ducting how important is it to heat/warm the holding tanks?
We live in AZ but can reach freezing and hope to travel but not in the dead of winter.
Thanks in advance
Hittenstiehl
Sorry no pics. couldn't figure how to post, URL problems.
Hittenstiehl is offline   Reply With Quote
Old 06-21-2013, 08:58 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by Hittenstiehl View Post
Greetings:
It would be enough to keep an already warm trailer 20-30 degrees warmer than the outside temperature if there is no wind. You have to keep a window open when using catalytic heaters. They pose both safety and humidity problems particularly when used as the only source of heat in colder weather.
Replacements for the existing furnace are readily available. Usually people adapt the Suburban NT series of furnaces, which are available in several sizes. A technician familiar with Airstreams can complete the install in around 2 hours including adaptation of the ductwork and constructing a mounting platform.
I don't believe that the ducting to the holding tanks makes much of a difference although since it's the sort of thing that's difficult to determine experimentally without damaging a trailer or two I don't think we really know.
Old 06-21-2013, 07:04 PM   #3
1961 28' Ambassador
Mesa , Arizona
Thanks for your input. Going to mull it over and decide.
Hittenstiehl
