Old 05-13-2006, 10:21 PM   #1
1964 24' Tradewind
Jamestown , Missouri
international 1525 furnance wire diagram
does anybody have one? I've run into some problems.
I figure out the thermo switch wire, and I think I figure out the power supply line. I check continuity in the supply w/ meter at furn. then flip breaker and still had continuity, unpluged the 50 amp main line and no continuity. I have no power going to the furn, 120V or 12V. So this confuses me. All that most likey doesn't much sence to you all?
I ran a new supply to the furn. from breaker box I connected it to furn. it makes a thump and then a low hum.
So I have a old supply line with no real power that goes somewhere. and a furnance that humms when it does have real power.
Can anybody help out?
BUSHKO is offline   Reply With Quote
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
wiring diagram? nu2argosy Electrical - Systems, Generators, Batteries & Solar 2 04-20-2004 07:30 PM
Connector Diagram at AIRSTREAM smily Brakes & Brake Controllers 0 09-10-2002 08:02 AM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 08:25 PM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 09:00 AM
