Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 05-31-2016, 07:01 PM   #1
2014 28' Flying Cloud
Boca Raton , Florida
Interior Temperature Sensor not Working
I have a 2014 28' FC with a Dometic A/C and thermostat. The interior temperature sensor indicated that the interior temperature is 32 degrees F. The actual temperature is 84 degrees. As a result only the furnace is working to increase the interior temp. I have tried to re-set the system per the instructions in the manual to no avail. I called the Dometic service center and after they walked me thru another reset without a solution, they suggested I go to a service dealer. My question is-has anyone had a similar problem? Were you able to solve the problem yourself? I am willing to take the unit to a RV dealer but we are traveling and are presently in Raleigh, NC for 2 weeks visiting with family. Can anyone give me a recommendation for a reliable dealer/service center. Thanks
Joohntooth is offline   Reply With Quote
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
New MicroPulse Sensor and re-cal... post mortem on old sensor RFP General Repair Forum 10 10-25-2017 07:29 PM
Fantastic Fan - Rain Sensor Not Working jbroedlow Roof Vents, Skylights & Fans 6 05-15-2016 03:43 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Holding Tank sensor not working, Need help garyashley 2005 and newer - Bambi all models 1 05-16-2010 08:13 PM
