Old 06-05-2007, 06:25 PM   #1
toadtogo's Avatar
1981 31' Excella II
Midlothian , Virginia
Interior A/C cover
Okay, I am stumped..... My interior A/C cover seems to be troublesome. It is secured by two screws; mid-line front and back. The back screw is directly over the header for the screen between the kitchen and the twin beds (rear bath model). I removed the rear screw by drilling a hole through the track header. I then found out that when you tried to shift the cover to the rear to clear the control shafts, the filter panels prevented the cover from being slid along the ceiling to the rear beyond the header. Likewise the header prevents the cover from being lowered after clearing the control shafts and moved forward for removal...
So, beyond, what seems to be a major privacy screen frame removal, does anyone have a solution???? Thanks
1981 Excella II 31' (rehab project)
2005 Jayco Eagle 322 FKS
2004 F-250 PS King Ranch
Retired & Having Fun
toadtogo is offline   Reply With Quote
Old 06-05-2007, 10:03 PM   #2
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Hello,
I am clueless about your 1981 and your A/C cover. But, if you can take a photo and post it I am sure you will get more responses. What are you trying to do anyway? Take off the screen frame? Change filters? Repair something else?
You might use the search tool for 1981 A/C and see if anyone has pictures posted from some repair, etc. buried in a file somewhere!
Good luck.
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 12:05 PM
cover for univolt maznblu Electrical - Systems, Generators, Batteries & Solar 2 09-15-2002 07:02 PM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 10:54 AM
Trailer Life cover 83Excella Our Community 6 06-16-2002 10:14 AM
