Old 05-13-2010, 06:45 PM   #1
gbesley's Avatar
1984 27' Sovereign
Ranchos de Taos , New Mexico
installing new water heater
I just purchased a new Atwood 6 gal. replacement water heater for my "84 25' Sovrn. I disconnected the old one and tugged it out, switched the plumbing fittings and slid the new one in. The hardest part was the sliding out and in as the fit is very tight but it goes. It was easy enough for a duffer like me.
gbesley is offline   Reply With Quote
Old 06-18-2010, 07:19 AM   #2
Alvinsolar's Avatar
Sydney , NS
Re:
Hi,
Exchange the heater with the new ones......
eco home assessments
Alvinsolar is offline   Reply With Quote
Old 06-20-2010, 09:42 PM   #3
Ottawa , ON
Was there was already a by-pass built in, or did you install one? This was your opportunity to look after that, just in case that trailer ever decides to spend a winter up north.
By the way, did your original door fit the new unit, or did you have to use the plain beige one that came with the new heater?
Old 06-22-2010, 07:42 PM   #4
gbesley's Avatar
1984 27' Sovereign
There was a bypass installed on the piping behind the unit and it fit and worked. The door that came with my unit worked. It was a very simple matter of unhooking the old unit, pulling it out, sliding the new unit in and attaching the existing plumbing. The only problem and it is just minor is that the latching mechanism is hard to pull far enough out to turn and lock. I think this will free up with time.
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
Installing new water heater now! HELP rochsmama Water Heaters, Filters & Pumps 27 05-19-2005 07:57 AM
Installing fresh water tank warrencindy Fresh Water Systems 6 02-17-2004 02:59 PM
