Old 06-02-2011, 03:23 PM   #1
1964 26' Overlander
houston , Texas
Images: 11
Installing a new A/C-1962 Tradewind
I have a question on installing an ac unit on my 1962 trade wind.
My trailer has a popup vent that I removed. My question is should I cut the raised frame from the popup vent flush with the trailer then set the ac unit on that? This is might be a stupid question but I wanted to ask before I started cutting on my trailer. On my next post I will enclose pictures. Thanks Scott
harrison is offline   Reply With Quote
Old 06-02-2011, 03:29 PM   #2
1964 26' Overlander
houston , Texas
Images: 11
here are the picture
ID:	131387   Click image for larger version
Old 06-02-2011, 03:34 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
The roof might not be reinforced to support an air conditioner.
If it is, yes, you would have to remove the curb.
Old 06-02-2011, 03:38 PM   #4
1964 26' Overlander
houston , Texas
Images: 11
How would you reinforce it if it was yours?
Old 06-02-2011, 03:44 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Ask around. There may actually be a reinforced area further to the rear.
Otherwise, you might want to consider something besides roof mount.
Old 06-06-2011, 09:15 PM   #6
Dan Clayton's Avatar
1956 22' Flying Cloud
West Linn , Oregon
Images: 14
I have never heard of needing a reinforced area on an Airstream to support an air conditioner. Airstream from what I understood would just add the unit as a dealer option, and they never added a additional support that I was told, and how would you go about adding it in the first place. This would be a good question for Andy.
Dan Clayton is offline   Reply With Quote
Old 06-06-2011, 09:26 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Ceiling reinforced
When my husband & son installed a Penguin Low Profile on my daughter's Argosy Minuet, they reinforced the ceiling by making wood that went with the profile of the curve in the ceiling. They were placed as pictured to support the roof from caving on the sides (front to back) of the a/c. My husband also installed an a/c on my previous AS & did the same thing. It's basically a shim to keep things square & weight distribution even so leaks are less (theoretically!) This was suggested by others on this forum. So far, so good for the install!
ID:	131868   Click image for larger version
ID:	131870   Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-06-2011, 09:41 PM   #8
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Current AC units attach to the trailer by clamping it to the outer and inner skins. Without the reinforcement between the two skins, the skins will bend and buckle. I did the same as pictured above (with a lot of help, thanks Zep!) and it has held up for a couple of years now.
The original Armstrong on my 75 was attached to the outer skin only with 40+ screws in the skin. Even with the weight of the unit distributed over a larger area of the roof, the old unit had started to bend the outer skins.
Richard
Old 06-07-2011, 05:53 PM   #9
1964 26' Overlander
houston , Texas
Images: 11
Thanks for your help. That is what Im going to try.
Old 06-08-2011, 07:55 PM   #10
1963 19' Globetrotter
Moline , Illinois
I had a Coleman unit installed on my Globetrotter at a very reliable dealer who was recommended by a fellow forum member . To properly place it , a new hole was cut (vent remained and now has a Fantastic fan in it) and the area around the cutout was reinforced with wood. I was not sure of the location and did not want to goof up the cut . I did the electrical which the dealer said was the hard part and it was a challenge. The A/C should be on its own breaker with 12 ga minimum wire ( I used 10 ga. ).
63air is offline   Reply With Quote
Hello from Suffolk, England - 1962 Tradewind beachhutlife Member Introductions 8 04-13-2012 06:51 PM
1961 Tradewind Custom dorchstream Member Introductions 5 05-07-2011 08:51 AM
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 02:34 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
1962 Safari numbers jaclaw Airstream History 5 01-18-2011 07:48 PM
