Old 02-28-2007, 07:23 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Installing A/C on my 1960
I'm getting ready to install an Penquin A/C on my Ambassador.
I'm putting it in the center 14x14 existing vent. It looks like the A/C will be centered over one structual rib.
I plan on framing out the opening w/ 2"x4"'s for support.
I don't have the ceiling opened up so no opporunity to frame in extra support besides what can be done through the opening.
So, is this a good plan? Anything I'm not thinking about?
Thanks!
-Tim
theVAP - Airstream Podcast
Old 02-28-2007, 08:02 PM   #2
toastie's Avatar
1955 22' Safari
Great Lake State , .
Thanks!
Make sure that you get a drip pan from Airstream, "only" Airstream makes a drip pan for the Penquin................
toastie is offline   Reply With Quote
Old 02-28-2007, 09:59 PM   #3
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Got it!
-Tim
Old 02-28-2007, 10:07 PM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Only thing I'd have done differently would be to add a drip pan. Although not much condensate runs down the side here in sunny AZ when the temps are up. Been really happy with the install.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 02-28-2007, 11:12 PM   #5
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Brad, did you re-enforce the roof any?
-Tim
Old 03-01-2007, 04:48 AM   #6
rideair's Avatar
Shape not flat!
Tim,
I spoke to someone about this that restores trailers for a living. He told me that he uses a peice of aluminum for the support not a 2x4 and the peice of aluminum is "shaped" to the contor of the roof like the ribs. If you use a 2x4, you could/will create a "flat spot" in the roof when you tighten it down. That is not so much of a problem with the newer trailers(they have flatter roofs). The older ones have more of a rounded roof line.
Good Luck
Paul Waddell
rideair is offline   Reply With Quote
Old 03-01-2007, 04:54 AM   #7
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Greetings Tim-
I would reconsider using wood and go with aluminum for your box frame. This way you will be able to rivit it in place and save on the weight. Also you won't have to worry about rot. The drip pan is a must. Call JC or your local dealer for that. Be sure to contour the upper portion of your new aluminum frame to the roof arch.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 03-01-2007, 05:39 AM   #8
1960 24' Tradewind
Riverside , California
ac install
You should create a truss support between the inner and outer skins, this truss should be 1 7/8" thick on the sides and the front & rear ones should be curved on the top and flat on the bottom about 2 1/4 - 2/ 1/2 in the center to 1 7/8 on the ends. This will maintain the exterior curve and give you a flat inside so you ceiling pack looks good, also a necessity when installing a Carrier, lets the air sweep work easier.
ZoomZoom
ZoomZoom is offline   Reply With Quote
Old 03-01-2007, 06:38 AM   #9
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I did re-enforce the roof from rib to rib with 2 x 2's, 2 on each side so they would contour the roof better than a 2 x 4. Used an metal angle bracket at each end to secure to the rib.
FF
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
A/C removal Rob Furnaces, Heaters, Fireplaces & Air Conditioning 14 04-22-2003 06:53 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 10:30 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
