Old 06-23-2015, 04:15 AM   #1
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
I'm Melting! AC stops after few minutes?
We are unable to test our original 1980 AC at home because we do not have a 30 amp outlet to hook up to. (It had not been run for at least 10 years prior to us buying the trailer) While camping last weekend, (and hooked up to 30 amp) we tried the AC. We turned it on low cool and it ran for just a few minutes, then shut off. After trying it on high cool, fan, any setting, it would not turn back on. It did not trip the circuit breaker, but we have no idea where to start to check it.
It was warm in the trailer when we turned it on, so it should have run much longer.
We did repairs to our fridge a few weeks ago and I had to disconnect the AC thermostat wires (at least, I think that is what they were according to the service manual, one white, one black), but reconnected them securely when we were finished with the fridge.
We tried searching other posts, but were hot and frustrated, so our apologies if we missed it.
Jenn & Robb & our two furry kids
Maizie ('the Black Dog') & Dex ('the Brown Dog')
1980 International 31
WBCCI #4447
AIR #70157
Rhino33 is offline   Reply With Quote
Old 06-23-2015, 04:25 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What brand A/C is it? Does it have a remote thermostat or is it part of the ceiling assembly? Does the fan still run, or did everything shut off?
Old 06-23-2015, 05:17 AM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Did you check the circuit breaker on the power pole at your campground site? Sounds like you tripped a breaker. You can test your AC at home by purchasing a 30amp to 20amp adapter. Walmart or any camping store will have one. Then you can plug it in to a household outlet. (110 outlet on 20amp breaker in your house panel)
mayco is offline   Reply With Quote
Old 06-23-2015, 05:24 AM   #4
mayco's Avatar
Name:	ImageUploadedByAirstream Forums1435058665.936270.jpg
Old 06-23-2015, 05:41 AM   #5
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
Did the whole ac unit quit working or was it just the fan? When it quit could you still hear the compressor running? If so it could be the fans thermal breaker tripped its internal to the fan. It will reset automatically when the fan motor cools back down. Mine did this it was because there was about 15 pounds of pine needles inside my ac unit on the roof and the bearings needed oil.
bellastream is offline   Reply With Quote
Old 06-23-2015, 11:10 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by mayco View Post
Attachment 241399
It is not a good idea to use that on a 15 or 20 amp household circuit. I fried a receptacle doing that. 30 amps is too much draw on a 15 or 20 amp standard receptacle. Then, I had an electrician install a 50 amp receptacle.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-23-2015, 11:40 AM   #7
mayco's Avatar
The AC draws about 15 amps during start up
Old 06-23-2015, 12:36 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Sorry, but that is incorrect. On start, the fan initiates at about 3 +/- amps. When the compressor starts, it has a transient load of over 50 amps which then becomes FLA or full load amps of between 10-13 amps, depending on the size of the compressor and the outside ambient temperatures.
The data tag on the unit will give specific values for FLA, LRA (locked rotor amps) and fan. The large amperage required for starting is usually compensated by the capacitors, but if you have a meter the records inrush current for AC circuits and is also RMS, you will see the large transient draw for starting.
That is not to say that you can't operate a roof A/C from a household 20 amp circuit. You must be certain that the circuit is indeed 20 amps, and you will need a 10 AWG extension cord to assure that there will be little to no voltage drop by the time the voltage reaches the trailer.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 06-23-2015, 01:00 PM   #9
2010 30' Flying Cloud
Sandy , Oregon
AC Problem
Well, if in fact the AC has not run in 10 plus yrs., the seals could be bad and refrigerant has leaked out. I would take the trailer in and have the AC checked out. As mentioned in another response, I would have your electrical outlet for the trailer upgraded to 30 amps if you have one AC unit and 50 if you have two units. You should run the AC unit at least 1 to 2 times a year, to lubricate internal parts and seals.
Good luck, AC repairs are not cheap.
carlose is offline   Reply With Quote
Old 06-23-2015, 01:47 PM   #10
Rhino33's Avatar
Cincinnati , Ohio
I will have to double check the brand - I have Dometic written down, but I think that was for the fridge parts I was searching for.
There is not a remote thermostat, it is part of the ceiling assembly. The entire AC shut off after a few minutes, though other electronics in the trailer were still working (a vent fan).
WBCCI #4447
AIR #70157
Old 06-23-2015, 01:50 PM   #11
Rhino33's Avatar
Cincinnati , Ohio
The whole unit quit working and we could not hear the compressor run after the shut down...
We replaced the shroud last year and cleaned out and around the AC, so we don't think there is much clogging it.
WBCCI #4447
AIR #70157
Old 06-23-2015, 01:53 PM   #12
Rhino33's Avatar
Cincinnati , Ohio
We're afraid that service will not be cheap, but would love to have it operational. (or purchase a new one) Our trailer only has the one unit and we would definitely use it often throughout the year as it also has a heater built into it.
Keeping my fingers crossed...
WBCCI #4447
AIR #70157
Old 06-23-2015, 02:16 PM   #13
merchantmm's Avatar
2015 27' Flying Cloud
Yorba Linda , California
Had the same thing happen to me this weekend. We were running our Ac and as we turned on the water heater the AC went off. All breakers in the trailer were fine. It was the campground power that had flipped a breaker. We changed over to propane on the water heater and were able to restart the AC.
merchantmm is offline   Reply With Quote
Old 06-23-2015, 02:17 PM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I've been running the AC on the Safari today while doing a repair on the cabinets. I hooked up the trailer's 30 amp #10 power cord to an adapter, to a 25' #12 drop cord, then to a 15 amp receptacle on a 20 amp circuit. I turned off the converter so there would be no load other than the AC. The AC was running continuously, so there has been only one startup cycle. No breakers tripped, even though it ran it 4-5 hours. It was nice and cool inside the trailer and it's 95 outside.
Alan
A W Warn is online now   Reply With Quote
Gas Water Heater Stops Running After a Half Hour or So interstateflyer Water Heaters, Filters & Pumps 24 06-14-2015 02:38 PM
Inverter Switches Off After a Couple of Minutes Ljsydney Electrical - Systems, Generators, Batteries & Solar 9 03-25-2014 09:28 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Flood light lens melting nickcrowhurst Lights - Interior & Exterior 5 12-24-2003 08:38 AM
