Old 07-06-2011, 05:43 PM   #1
1966 22' Safari
Seven Valleys , Pennsylvania
If you were going to install a new low profile AC...
which one would you use? I'm looking at 13,500 BTU for our '66 Safari project. Wall thermostat would be nice. Would you bother with the heat strip? Will not be used in real cold much at all. Any ideas & past experiences good or bad with different manufactures would be appreciated before I buy something.
scarylarry is offline   Reply With Quote
Old 07-06-2011, 06:35 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Not specific to which unit ot get, but I would get the heat strip without question. When camped with hookups it's a whole lot better using their electricity than my propane. And it's handy to just take the morning chill off.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 07-06-2011, 10:16 PM   #3
1966 22' Safari
Thanks for the response, now anybody have an opinion about brand. There is not a long list to choose from.
Old 07-07-2011, 09:57 AM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
I don't believe there are any low profile units available except from Dometic at this point.
Old 07-07-2011, 10:19 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
My furnace makes about a third the noise of running the rooftop unit. Propane is pretty inexpensive if I'm trying to sleep. But the heatstrip is still worth it for giving you more options.
5 meter Langford Nahanni
Old 07-07-2011, 10:22 AM   #6
Nosurf's Avatar
1966 26' Overlander
Abilene , Kansas
Dang hotrodders.
Nosurf is offline   Reply With Quote
Old 07-07-2011, 11:05 AM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Coleman still makes a low profile too:
Low Profile Air Conditioners on Sale - PPL Motor Homes
Old 07-07-2011, 12:38 PM   #8
Cracker's Avatar
Pittsfield , Maine
We have the Dometic Penguin reverse-cycle A/C. It works as advertised, using the wall thermostat, but it was a lot more expensive than a heat strip would have been. That said, can anyone suggest an advantage of the "reverse-cycle" vs the heat strip? I've had both, and both are equally great for taking the morning chill off - but, since the compressor has to run, the reverse-cycle is definitely noisier.
Cracker
Cracker is offline   Reply With Quote
Old 07-07-2011, 02:10 PM   #9
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Between the two, a heat pump is better if YOU are paying for electricity and the outside air temp isn't too low, a resistive heater works fine if someone else is footing the electric bill.
David
DKB_SATX is online now   Reply With Quote
Old 07-07-2011, 02:56 PM   #10
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Carrier discontinued making rv air last year. But, here's a bargain if you don't mind repainting the shroud:
NEW RV Air Conditioner Carrier AirV 13,500 LOW PROFILE | eBay
Carrier had the set up for the drain line already built into the unit. A Google search will turn up a few more places that seem to still have a few left in stock.
Old 07-08-2011, 07:51 PM   #11
Cracker's Avatar
Pittsfield , Maine
Interesting!!! I would have thought that the heat pump would be roughly equal to the resistive heater with respect to power consumption. Live and Learn.
Cracker
How to Add Profile Picture? crzycpa Our Community 3 06-30-2011 10:43 AM
Best low profile roof top A/C unit??? hotstuff Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-29-2011 07:08 PM
