Old 11-13-2009, 09:01 AM   #1
1977 21' Globetrotter
Davis , California
Identity of small floor duct
This is a photo of a small, about 1 1/2" piece of grey ducting that extends from below the floor (near the axle below, and water heater) into the space under the side gaucho in my '77 21' Globetrotter. Discovered after removing the gaucho as part of a renovation project. I cannot see any means of connection to the furnace, located on the opposite side of the trailer (furnace has been removed for replacement). Help identifying its purpose and origin/destination would be appreciated, as the service manual doesn't seem to provide any info.
Maybe it's just a crawlspace for rodents!
flyflinger is offline   Reply With Quote
Old 11-13-2009, 01:15 PM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
That hole in the floor looks like it was cut after
it left the factory...but I am not sure.
kennethowens is offline   Reply With Quote
Old 11-13-2009, 04:40 PM   #3
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Heater duct for water and waste tanks
Birdwell57 is offline   Reply With Quote
Old 11-13-2009, 09:28 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's almost certainly a duct for the holding tank warmer. If if it is not that, the only other thing it could be is a duct for the bathroom vent, but it is in the wrong location for that.
Old 11-14-2009, 01:55 AM   #5
Mexray's Avatar
1978 28' Ambassador
Morada , California
OK, OK, now I get it! Show us all the REST of the elephant you've got helping you with that renovation...
Ray & Pat; Morada, CA
Old 11-15-2009, 06:53 PM   #6
Davis , California
Thanks to all of you for your input. I think I'm dealing with a duct system modified by the PO. I believe the cutout for the refrigerator ventilation was enlarged (it's about 6X9 in. now) and adjacent ductwork that feeds across the trailer removed at that time.
ductwork, furnace
Identity problem help ? beelertank Member Introductions 10 11-10-2009 07:10 PM
Is furnace duct hose the same as household dryer duct hose? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2009 10:21 PM
Floor rot in small spot! Anniedog Repairing/Replacing Floor &/or Frame 3 06-29-2008 12:31 PM
'69 Caravel - Identity of Roof Vents Julison 1969-1971 Caravel 4 09-30-2005 09:17 AM
Identity Protection RV and Home FrankR Off Topic Forum 0 09-10-2002 09:26 PM
