10-24-2008, 12:30 PM
Alisons Alley
1976 31' Excella 500
Pleasantville
, New York
I need some heat! Best options advice needed!
Hello!
I just got my first Airstream (1976 Excella ctr bath) and plan to renovate/update through the winter--but its getting cold! The furnace is shot and the original heat pump in the AC doesn't seem to really heat (?). Has anyone ever tried installing radiant heat in the floor? (mine is down to the wood at the moment getting ready for Pergo) ...Has anyone ever installed a small gas 0 clearance fireplace?
What is best for snow country?
Thanks!
Alisons Alley
10-24-2008, 12:51 PM
Retired.
, At Large
If you aren't going to have any water in it, you can go with a catalytic heater. We have one in our Sovereign, and it warms the trailer nicely down to about 25 degrees. It may do better, but that's all the colder it's ever gotten while we were in it.
One thing to know about the orignal heating system, it was ducted into the holding tanks, to keep them from freezing during cold weather. If you plan to use the water and holding tanks when it's cold, you'll have to take that into consideration.
10-24-2008, 01:04 PM
Princeton
, New Jersey
If you want heat while working in the trailer during the winter a catalytic heater is the way to go. Since they are a radiant type heater they heat you long before they heat the box.
You can get units that mount on a small propane bottle or install an Olympic on a frame while working and have it to install permanently during your finish work.
2004 Excursion 4x4
10-24-2008, 02:24 PM
1994 34' Excella
Mount Vernon
, Kentucky
I would stay with the propane furnace system. A new replacement would give you many years of comfy, toasty heat.
10-25-2008, 05:03 AM
2001 34' Limited
The State of
, Ohio
If you have not already done so, you need to drain the fresh water, grey water, and black water tanks, as well as the water heater and all the plumbing before the temperature starts dropping below freezing.
The furnace in an Airstream heats the tanks and plumbing between the floor and belly pan below them. There is no substitute if you want to have functional, undamaged plumbing in the winter.
Maurice
10-25-2008, 09:54 AM
1973 31' Excella 500
Morristown
, Tennessee
Hello, Pleasantville
I have the 1973 Excella model. It was standard with the catalytic heater near the entry dor as well as forced air powered by the Suburban heater. I plan to keep both for several reasons. Versatility is important and if away from a KOA, keeping the fresh water and holding tanks from freezing. The catalytic heater will operate, like the gas light in my box, without 12 volt It's a small cost for a real restoration of the ultimate aluminum package. It's my theory that you won't regret it.
Joe
11-18-2008, 08:52 AM
WBCCI 8562
1975 31' Sovereign
Pelzer
, South Carolina
I had the same problem, installed the catalytic heater, and ran the furnace blower to circulate the heat...worked ok, but decided now to replace the furnace
11-18-2008, 09:18 AM
1984 28' Funeral Coach
Belleview
I put electric heat mat down before we tiled the kitchen floor. It works very nice at home but I'm not sure about putting it below Pergo. Best check with the manufacturer of the flooring material.
I'm a big fan of the electric radiant heat in the floor. It's very efficient in the use of power as well as production of heat.
In the motorhome I'd be tempted to put a reflective barrier down first if the flooring material will handle the heat mat below.
I used Thermosoft. Warm Tile, Electric Floor Heating - ThermoSoft
There are other resources if you google "Electric Floor Heat Mat". Nuheat has product for engineered floors.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
