Old 01-03-2010, 10:46 AM   #1
2007 27' Classic FB
Havelock , North Carolina
Hydro Flame furnace blower quit working won't start
I have a Atwood Hydro Flame 8525 IV that just failed. I had been using it off and on because i keep the heat on when its in the driveway and the temps drop. Yesterday when I went to check I heard the blower start then shut off after 5 seconds with a series of "clicks" about 10 seconds later it would do the same. It did this several times then nothing happens. I shut the TS off and then on, nothing still. Checked the fuse OK.
Checked the board with a meter and showed power to the power spade 13.6V. Turned the TS up and showed 13.6V at the blue wire at the white pins. Check the power out to the blower and reads 0V so is it safe to assume the onboard motor relay is toast?
nsteel is offline   Reply With Quote
Old 01-03-2010, 10:49 AM   #2
Spring Hill , Florida
There's a fan switch in the circuit and if that isn't closed by the air flow, the burner won't come ON.
zekethebear is offline   Reply With Quote
Old 01-03-2010, 10:58 AM   #3
2007 27' Classic FB
I should clarify, the blower (fan) does not come on at all. Power to the board, no power out to the blower.
Old 01-04-2010, 03:27 PM   #4
2007 27' Classic FB
Thought I would pass along.
Found out what the problem was. I took the board out and bench tested it inside the house and the relay worked and powered the fan terminal. Went outside connected it up to the furnace and it didn't work at all, no click no led. Checked voltage, all within range. Next brought in in the garage connected it to a jump pack and still not working. Heated it with a snap torch and it started working...
Placed it back in the airstream -not working, hit it with a hair dryer and it snapped on.
Whats wrong about a heater not working in the cold It doesn't like the 20 degree temps any more than I do.
I ordered a new board from Dinasour Electric.
'65 Caravel Hydro Flame valve control unit teeraniti 1965 Caravel 7 01-09-2016 08:59 AM
Help! Dash Air/Blower and Rear Monitor both quit spat61 General Motorhome Topics 0 09-20-2009 06:26 PM
blower of suburban does not start when cranking up thermostat turfclubroad Furnaces, Heaters, Fireplaces & Air Conditioning 13 09-11-2009 12:38 PM
OK, Atwood Hydro Flame 8012 12K just got expensive ronstory Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-13-2009 10:50 AM
Hydro Flame butchncandy General Motorhome Topics 1 01-12-2009 06:20 AM
