Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-03-2009, 06:31 PM   #1
Profile:  Vancouver , B.C.
How to use the furnace in a 1973 Airstream?
I have use of my friend's 1973 Airstream that she has parked on a rural property but we can't figure out how to light the furnace.
How do I do that?
hublocker is offline   Reply With Quote
Old 11-03-2009, 06:35 PM   #2
munimula's Avatar
Profile:  1993 34' Excella
1964 24' Tradewind
Rockaway , New Jersey
turn the propane tank on. switch the thermostat to the on position. slide the temp level to where you want it. after 20 seconds or so you should hear a fan turn on then some clicking sounds. that is the igniter trying to light the propane. if the planets are aligned your furnace will start heating the rig.
other will chime in with more details.
Morrison's Airstream Page
munimula is offline   Reply With Quote
Old 11-03-2009, 06:59 PM   #3
Igniter?
What is supposed to drive the fan and igniter?
Old 11-03-2009, 07:02 PM   #4
munimula's Avatar
1964 24' Tradewind
fan and igniter are powered off the 12 volt system batteries.
Old 11-03-2009, 07:01 PM   #5
cameront120's Avatar
Profile:  1972 25' Tradewind
Before doing the above, you need to light the pilot light. There should be a little threaded cover that once open will reveal the pilot to you. Make sure the gas is turned on and the thermostat is off. It must be off, or you will experience a blast of fire once that pilot lights. Hold a flame to the pilot and press in the black button on the face of the furnace. This gets the gas flowing to the unit and it may take several moments before the pilot stays lit. Once lit, the button can be released. Put the cover back on over the pilot light and then you can go to the thermostat and set your temperature. You will here the furnace fan kick in and things will almost immediately begin to get toasty warm inside. Also, please get yourself a carbon monoxide and propane gas detector, install it and keep it functioning. Where in Vancouver are you located?
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 11-03-2009, 07:14 PM   #6
"fan and igniter are powered off the 12 volt system batteries."
This is an older 2nd hand Airstream that probably hasn't had a new battery in 20 years.
Old 11-03-2009, 07:16 PM   #7
You will need a power source for this furnace to function. If the battery isn't working, then you will need shore power. The fan draws a lot of juice from the battery, so it will need to be recharged regularly if the furnace is used. If there is no shore power, then a generator would be needed.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 11-03-2009, 07:18 PM   #8
cameront120.
I'm in East Vancouver near the Cultch.
The trailer is in Princeton.
Old 11-03-2009, 07:22 PM   #9
Has the furnace been used at all recently? Does any one even know if it works? Given the time of year, has the trailer been winterized? Have the pipes and holding tanks been cleared?
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 11-03-2009, 07:29 PM   #10
She bought the trailer 2nd hand last year and towed it to her property.
She couldn't get the stove going so I went in October 2008 and found all the right valves to turn on and got that going.
As far as I know nothing else works in the trailer, particularly water. It's anyone's guess as to when the furnace last ran.
And to be honest, I don't know where the battery lives.
Old 11-03-2009, 07:39 PM   #11
Do you know what model of trailer it is?
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 11-03-2009, 07:44 PM   #12
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
How to use a 1973 Furnace.
The best use of a 1973 Furnace is as an anchor.
All seriousness aside. I had a 73. Parts are unavailable or extremely hard to find, as are techs who will work on them. Techs won't work on them for liability reasons. The can be dangerous. If there is a leak in the combustion chamber they can croak you.
I stubbornly would not give up on my 73 furnace. Most owners of early 70s I have heard from eventually decide to replace the furnace with a new model. as I finally did. Not a hard job.
Pay no attention to the man behind the curtain- WoZ
Old 11-03-2009, 07:47 PM   #13
Well it's on a rural property, no power, no generator.
I guess it's an icebox.
Old 11-03-2009, 08:21 PM   #14
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Send a message via ICQ to Aage
As Lumatic pointed out, it may well not be a good idea to get it going. They rust inside as they age, so at a certain point they become unsafe.
Would you use a 36-year-old furnace in a house? Not likely, unless you had it serviced very carefully, right?
Also, even if it worked, you need power (which means an investment of some kind). It may be time to step back and consider just how far you want to take the winter use idea...
The road to a friend's house is never long. (Old Danish Saying)
1973 Airstream eBay Watch Airstreams on eBay 0 07-19-2009 04:50 PM
1973 airstream ambassador eBay Watch Airstreams on eBay 0 07-14-2009 09:50 AM
1973 Airstream Trailer eBay Watch Airstreams on eBay 0 05-27-2009 03:12 AM
1973 Airstream Value TimeOut Trailer Values 23 11-14-2007 10:49 AM
1973 Furnace Book 74SovereignInt. Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-08-2002 08:59 PM
