Old 05-27-2009, 09:17 PM   #1
1990 36' Land Yacht
Nelsonville , Ohio
How to run both roof air units
Newbie here guys!! I just bought a 1990 36ft Land Yacht... LOVE IT... I can only get one AC unit to work at a time... I did eventually find the switch in the cabinent above the sink to switch between the front and rear units... initially thought the back unit was bad but it works!! Owners manual says both ACs can work when Gen is running.... any ideas???
RoyTabernick is offline   Reply With Quote
Old 05-27-2009, 10:51 PM   #2
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
The generator must run to use both A/C units. This is by design as the 30 amp power cord can't handle the higher power use. You must rewire for 50 amp cord if you want both units running together. I don't think the cost is worth the conveinence. I try for shadier areas to minumize needing both units.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 05-29-2009, 08:59 AM   #3
1990 36' Land Yacht
Nelsonville , Ohio
Ok.. I do remember reading that... but when I have Gen on it will only run one at a time... is there a switch or something that I am missing? I have located the one above the galley... I thought the rear air didn't work until I found the switch..I flipped it and the rear air started working.. but then the front air doesn't work.... I am assuming there is another switch or something??
I am a newbie....I appreciate the help!!
Problem running both roof AC units BW_LandYacht36MH Electrical - Systems, Generators, Batteries & Solar 3 08-22-2005 06:55 PM
Roof Air TOM CRUMP Our Community 2 09-09-2003 06:15 AM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
