Old 12-21-2015, 09:35 AM   #29
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Don't think it will work there
Originally Posted by Tom_T View Post
Tex,
Double check your water heater space when you get that Suburban in hand to measure it & the fittings, cuz you may find it can tuck in nicely next to the water heater, "Y" off the gas & 12V already there, vent out the same place as the water heater (door or wall vent) - plus not give up that drawer space under the fridge - with space so precious in these smaller AS/Vintage Kin trailers.
Good Luck & Happy Holidays!
Tom
Water heater is under the (rear) bed and vents out the curb side wall just forward of the end cap curve. Mounting furnace behind water heater would be nice in terms of access to LP and power but:
1. Would have to be mounted on curved wall.
2. Would be a long way from the front of the bed, which would require reconfiguring grill arrangement somehow.
3. Would add weight in the rear, decreasing tongue weight.
BambiTex is offline   Reply With Quote
Old 12-23-2015, 09:40 AM   #30
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
The good news is that it will fit nicely in place of my lowest kitchen drawer. No cabinet mods required :-) Just need to cut a hole in the shell for the vent.
Old 01-19-2016, 06:18 AM   #31
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Need advice
OK, furnace installed in cabinet, 12 volt and thermostat wiring run, propane lines connected. Last task is to connect intake and vent piping through shell. Both are sleeved pipes that are inserted from outside the trailer. Vent pipe can accommodate a large range of distances but inlet pipe can only handle a small variation. Based on my cabinet depth and the slight curvature of the shell, the inlet pipe is approximately 3/16" too long. Even though it is just a straight, single wall pipe, instructions warn against cutting it and recommend purchasing a shorter custom part from the manufacturer. I see no reason why the pipe cannot be simply cut to length. Anyone tried this?
Old 01-19-2016, 06:56 AM   #32
Images: 59
You might consider building a little frame around the vent pipe to help compensate for the curvature and keep the assembly vertical. I think it also has a more "finished" look.
ID:	255957   Click image for larger version
Old 01-19-2016, 07:06 AM   #33
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Did you fabricate that yourself?
Old 01-19-2016, 07:14 AM   #34
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I think you could cut it no problem if you are careful... But,,,, if you do screw up the cut, then you can order a new custom tube...
Brevi tempore!
Old 01-19-2016, 07:34 AM   #35
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Don't see how one could screw up the cut. It is just a straight, single wall pipe.
From the manual:
Under no circumstances should the standard 5" intake tube be cut or altered to adapt to the 21" - 23 1/4" range.
Old 01-19-2016, 07:35 AM   #36
Images: 59
Yes. Just some scrap sheet and 1/16" aluminum cap channel.
Old 01-19-2016, 10:06 AM   #37
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
I'm wondering (hoping?) the exhaust leaves through the top pipe? Otherwise, with heat rising, you'd be more likely to pull the carbon monoxide exhaust back into the inlet directly above it.
I'll assume the manufacturer thought of this.
bredlo is offline   Reply With Quote
Old 01-19-2016, 10:07 AM   #38
bredlo's Avatar
1954 22' Safari
Beautifully done!! Looks almost mass-produced, in a good way.
Old 01-20-2016, 05:40 AM   #39
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Yes
The top pipe is the outlet and the bottom pipe is the inlet so exhaust gases should not enter inlet.
I had no trouble cutting the pipe. Stainless cover plate needs to be "caulked" to shell. Anyone know if butyl tape would work ok? Much less messy..
Old 02-11-2016, 05:37 AM   #40
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Installation pics
I was very lucky that no cutting of the cabinet was required. Furnace fit nicely in the space previously occupied by the lowest kitchen drawer.
ID:	257139   Click image for larger version
ID:	257141   Click image for larger version
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
Add your trailer type... malconium Our Community 5 07-09-2004 01:36 PM
Add your event to the Calendar! Andy R Forum Admin, News and Member Account Info 0 02-27-2002 09:22 AM
