Old 12-15-2015, 11:51 AM   #15
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Have you considered using an automobile heater core + fan and plumbing it into the hot water heater? A cheap 12 volt recirculating pump to keep the hot water moving would complete the install. No furnace required. Argosy Rover did radiant heating in the floor using pipes laid on the sub floor, insulating foam between the pipes and a floor laid on top of that. The water circulating pump was wired to the thermostat. According to him the water heater was up to the task.
Gearheart is offline   Reply With Quote
Old 12-15-2015, 02:46 PM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
Radiant floor heat in an Airstream doesn't, by itself, provide enough heat in cold weather.
There are a number of problems using heater cores on fresh (drinking) water systems. The largest problem is that they are prone to corrosion and early failure when used with fresh water, because the water does not contain a corrosion inhibitor and because there is dissolved oxygen entering the water. They may also contain components, particularly lead, that are not safe for contact with drinking water. The system as a whole ends up being heavy and complex compared to better alternatives.
I like hot water heat and have lived in two different stick houses that have it. I do not believe it is a good choice for an RV.
Old 12-15-2015, 09:27 PM   #17
Central , Mississippi
I installed the heater in a '55 cloud under the bed with the exhaust in the rear corner. Reasons...
Under the sink was full of water heater.
Under the fridge didn't have enough room or the microwave wouldn't fit above it.
And, where it is now, the exhaust port is not under an awning or window.
It has 3 hot air vents. One exits from under the bed and is pointed at the bathroom. One routes forward, under the pantry and point toward the kitchen. The last routes even farther forward and exits the wall by the door and blows toward the dinette.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-16-2015, 11:39 AM   #18
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Opposite locations
My furnace will go under the sink and my water heater is under the bed with exhaust in the rear corner. Both on street side.
BambiTex is offline   Reply With Quote
Old 12-16-2015, 04:50 PM   #19
That's a good plan. This '55 has the bed on the curb side so sticking the water heater under it would have been a real hassle.
Old 12-17-2015, 08:49 AM   #20
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Rear Bed
Mine has the bed across the back. I put the LP water heater near where the old electric one was. Vents out the street side, and easy tie in to water main. Did have to run LP line though..
Old 12-17-2015, 09:12 AM   #21
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
How to add furnace to vintage trailer
Mine is on the wall....
Name:	ImageUploadedByAirstream Forums1450368742.119699.jpg
It was 22 degrees last night, it does a great job.
Brevi tempore!
Old 12-17-2015, 09:23 AM   #22
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Model?
Attachment 254014
Brevi tempore!
What heater make and model is that?
Old 12-17-2015, 09:35 AM   #23
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
http://m.homedepot.com/p/Williams-17...3512/202034919
If you go this route, it pays to shop around, I did not pay this much.
Name:	ImageUploadedByAirstream Forums1450370129.161421.jpg
Brevi tempore!
Old 12-17-2015, 11:11 AM   #24
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Wow. Picked up a Suburban 19,000 BTU furnace for under $300 on EBay. The Williams unit looks like it needs 110VAC for the fan. If I have shore power I can just run my heat pump.
Old 12-17-2015, 12:11 PM   #25
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I run mine through an inverter.
Brevi tempore!
Old 12-17-2015, 02:32 PM   #26
Tom T
Tom_T's Avatar
Orange , California
Agree about the catalytic heater. One came with the trailer and my wife refuses to use it so it is gone. On closer examination it appears I can put the furnace under the kitchen counter by giving up the lowest drawer. I feel better about having the exhaust vent on the street side as opposed to the curb side where we sit under the awning. Can tie into LP for stove but will have to run 12 volt wiring to that location.
Tex,
Double check your water heater space when you get that Suburban in hand to measure it & the fittings, cuz you may find it can tuck in nicely next to the water heater, "Y" off the gas & 12V already there, vent out the same place as the water heater (door or wall vent) - plus not give up that drawer space under the fridge - with space so precious in these smaller AS/Vintage Kin trailers.
Good Luck & Happy Holidays!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
Old 12-19-2015, 07:41 PM   #27
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
For those thinking about a Dickinson Marine fireplace (its official name is the Newport) there are a couple of propane units for sale around the country on Craigslist - and priced quite reasonably.
We already have ours, and would love to see more Airstreamers make use of these!
Santa Fe, NM:
Propane heater/ fire place
Cincinnati, OH:
Dickinson Marine P9000 Propane Heater
Juneau, AK or Shelton, WA (conflicting info)
P-9000 Dickinson Propane cabin heater
bredlo is offline   Reply With Quote
Old 12-19-2015, 08:01 PM   #28
bredlo's Avatar
1954 22' Safari
Santa Fe, NM:
Cincinnati, OH:
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
Add your trailer type... malconium Our Community 5 07-09-2004 01:36 PM
Add your event to the Calendar! Andy R Forum Admin, News and Member Account Info 0 02-27-2002 09:22 AM
