Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-09-2007, 02:28 PM   #1
Aluminumb
Profile:  1999 25' Safari
Sebastopol , California
How to Remove Furnace
I need some help. My furnace ( I think is a NT30SP in my 84 Excella 31') just stopped working a couple of days ago. I called our local RV place and they can work on it. I don't want to move the trailer as it took a lot of work to get it where it is...slipping and sliding all the way up the we hill !). So the problem is, I'm not sure how to take the furnace out? Any direction would be most appreciated.
Ben
Aluminumb is offline   Reply With Quote
Old 12-09-2007, 03:19 PM   #2
fotochop
fotochop's Avatar
Profile:  1969 23' Safari
New Orleans , Louisiana
Not sure if my '69 Safari furnace is comparable, but it was quite simple to get the furnace out. After carefully shutting off/removing the LP tank it's a simple matter of removing the LP feed line (use two wrenches) at the furnace, removing the exterior vent cover (mine was screen) and the exterior screw that holds the vent assembly to the trailer wall. Then I went back inside and removed the one screw that held the furnace from inside and it slid out. If your rubber vent seal is brittle be careful with it, or have it replaced. Much easier to 'bench test' the furnace outside the trailer. Mine was actually recalled by Suburban back in the day and the very unsafe recall issue had never been rectified by any of the PO's, it was a disaster waiting to happen.
Before pulling you may want to check a few other issues (battery voltage, thermostat etc) as recommended by a good repair manual like Woodall's. Would be a shame to go thru the pulling if it was something other than the unit itself. good luck
fotochop
fotochop is offline   Reply With Quote
Old 12-09-2007, 04:53 PM   #3
Aluminumb
Thank you. That helps. So the unit comes out without the box itself? So I don;'t have to remove the air duct lines from the box?
Old 12-09-2007, 05:02 PM   #4
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
no, the box comes out. The air ducts should be slip fit--just slide them up about 1/2" and see if they come loose.
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 12-09-2007, 07:00 PM   #5
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
You can take the cover off the outer box and then slide the guts out without taking out the box. It makes it lighter and easier but you need to disconnect the electrical connector from the side of the box before you start pulling out the guts.
Old 12-09-2007, 07:26 PM   #6
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
The problem with removing the NT30 furnaces without removing the case is that there is a retaining screw in the front of the unit holding the frame of the furnace to the box, and if long enough....to the trailer floor. This screw is very easy to get to ....if you have access to the furnace from the outside, as in an outer door.
Unfotunately, most Airstream installs do not use this mounting method and only reveal the intake and exhaust ports thru the skin. This requires you to remove the ducting ( only a quarter turn fitting) and then the entire furnace and outer casing as a unit, as you can not access this pesky little retaining screw from the rear of the furnace. Don't forget to unplug the 4 wires leading to it (assuming you have a plug) or mark the wires before cutting and add 1/4"insulated spade connectors for re-assembly.
Also, you have to turn off the LP at the tanks BEFORE you disconnect the LP feed line. If you are going to use the trailer, be sure to add the appropriate size flair plug to the line before returning the trailer to service.
OTOH, I have seen some Suburban models that have this little screw at the rear, or interior side of the furnace. In this case, the units can be removed without removing the casing. It sort of depends on the mounting method and specific model. The screw should be obvious to you (if you have it) once you remove the interior cover of the unit. It is locateed right inside th cover smack in the middle of the unit at the bottom position.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 12-10-2007, 09:51 AM   #7
Aluminumb
OK, thanks to all. I think I have enough to go try it. I'll let everyone know.
Many thanks,
Ben
Old 12-10-2007, 08:08 PM   #8
Aluminumb
I finally got it out. But there is a small pipe that extends from the bottom of the heater into the floor about 2 inches. If I raised the heater up, there was not enough room to pull it and the pipe out before the heater was above the supporting lower bar for the oven. So I had to clip the pipe off the lower part of the oven. What is this pipe? Did I do something very bad?
Old 12-10-2007, 08:34 PM   #9
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Originally Posted by lewster
...you have to turn off the LP at the tanks BEFORE you disconnect the LP feed line...
Ignoring this step leads to a slightly more distructive method of removing the furnace, worthy of a You-Tube episode however
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 12-11-2007, 05:07 AM   #10
Zeppelinium
1977 23' Safari
1975 31' Sovereign
Originally Posted by Aluminumb
...there is a small pipe that extends from the bottom of the heater into the floor about 2 inches. ... I had to clip the pipe off the lower part of the oven. What is this pipe? Did I do something very bad?
I'm going to take a big leap and assume you know it's not the propane pipe.
The only other guess I have is that it's a water drain--is it possible that there can be condensation in the burner and vent (maybe when the heater is cold and just starting) that needs to be drained? Or maybe in the forced air path for the same reason (cold at start)?
My experience on old heaters is that they are a pile of rust, so there's got to be water involved somehow.
Zep
Old 12-13-2007, 09:17 PM   #11
Aluminumb
Well its out. Its been at the repair center and they got it going. But when I went to pick it up, it wouldn't fire. We replace the board and it still wouldn't fire. The original board tested fine. Since I really need it to work, I started to think about what I was spending on a 1984 furnace. I bought a new one. I think its the right decision. Thanks to everyone for their advice.
Old 12-16-2007, 09:25 PM   #12
HiHoAgRV
Images: 26
Cheers to new heat.
Hi Ho Silver RV!
How to remove old sealant? FC7039 Cleaning, Stripping & Polishing 6 09-05-2007 11:14 AM
What will remove this stuff? jdalrymple Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-09-2007 08:14 PM
need to remove frig from '73 rhodyrunwv Refrigerators 3 05-13-2006 09:25 PM
70 Tradewind - How do you remove furnace? Herm and Debby Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-02-2006 04:19 PM
Difficult to remove AC? 71_safari Furnaces, Heaters, Fireplaces & Air Conditioning 5 07-02-2004 07:04 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
