Old 11-02-2007, 04:26 PM   #1
SafariSogood's Avatar
1975 23' Safari
Portland , Oregon
How much to replace a furnace
I recently acquired my '75 Safari and tried the furnace. It worked for most of one night when I was testing it (me not in it mind you) and it was working fine when I went to bed. in the morning the blower was on but the heat had stopped. Trying to light it after, it will light briefly, I will hear a noise from inside the furnace, and the flame is out when I check, I then smell rubber. I tried this several times, always the same result.
So after reading about other furnace tales here, I am taking your advice to replace and not repair.
I would want an automatic lighting model with a minimal amount of hassle. Would another Suburban be the answer or are there better options now and what should I expect to pay for a unit for a professional to install it?
Thanks all!!
SafariSogood is offline   Reply With Quote
Old 11-02-2007, 05:01 PM   #2
Thanks all!!
Your describing the behavior of a Suburban furnace, that is loaded with dirt in the combustion chamber. When the combustion chamber has enough dirt in it, it will suck the pilot light out almost everytime it shuts down.
The fix is to remove the furnace from the trailer and disassemble it on a bench.
That's when you will see at least a couple of cups of dirt falling out of it.
After a thorough cleaning, replace all the gaskets.
Bench test the furnace if you can, or reinstall it and start from the beginning.
CAUTION: Attempting to blow the dirt out of the combustion chamber with an air hose, first, will not get enough dirt out, and second, you could damage the combustion chamber.
A good RV repair shop can help you if you wish.
Even though your furnace is over 30 years old, it's not likely that it needs to be replaced, unless the combustion chamber is damaged or has a hole in it.
Again, you must remove the furnace to properly examine or repair it.
HELP!! Have to replace my furnace! '70verlander LP Gas, Piping, Tanks & Regulators 16 09-09-2007 08:46 PM
I want to replace my 1962 furnace Frank's Trailer Works Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-22-2007 07:36 AM
Need to replace this - but what is it? Tom Randall Phone, CB & Ham Radio 10 05-22-2007 10:40 AM
Duo-Therm Furnace (MH) repair or replace? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 12 12-30-2003 02:47 PM
replace 10 by 6 by WH CatandMe Water Heaters, Filters & Pumps 0 06-24-2003 12:16 PM
