1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel
How much condensation inside its normal?
While one of the AC units in the Avion is failing (bad burning smell), now the other looks like is having more condensation than normal.
Yes, its extremely humid outside, but inside the trailer seems to be ok.
How much condensation is normal in the Old Coleman Mach III
THAT is not even close to normal. If you have those other Airstreams you can compare. Loos like any drain you had is just that...had.
__________________ "If it can't be reduced, reused, repaired, rebuilt, refurbished, refinished, resold, recycled or composted then it should be restricted, redesigned or removed from production."
Air conditioning must have a way of collecting and getting rid of the moisture. Does the moisture collect in a container you have to empty?
On our last camping trip to very humid Jacksonville FL at the beach, our drain line was either plugged or constrained. We collected about two gallons of water a day in a bucket under the AC unit.
