Old 03-06-2007, 02:41 PM   #1
1986 32' Excella
vledder , drenthe
Images: 8
how long on a tank of propane
with the heater and the fridge running on propane fridge rm 2800
2 tanks gone in 4 days ,
seems a bit short for me.
what is the consuptin of the heater and fridge per hour.
thanks
Remco
remcolent is offline   Reply With Quote
Old 03-06-2007, 03:08 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
You have lots of variables here...
Propane tank size?
Outside temp?
Heater tempature setting?
Temperature desired?
Do you turn down heater when not there?
Fridge/freezer temp setting?
Fridge/freezer full or loosely packed?
Were fridge/freezer items already cold when loaded in?
Water heater size/demand?
Do you turn down water heater when not in use?
Number of meals cooked?
Oven used or just stove?
Gas light use?
Insulation in walls?
Insulation on walls - bare aluminum walls (paint) or fabric covered?
Draperies on windows (insulation)?
All these & more make a difference...four days with small tanks and high demand doesn't sound too unreasonable in the winter months to me ~
Shari
Old 03-06-2007, 03:15 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
thanks
Remco
Remco I can go almost a month on just the fridge on 1 30# tank and doing a bit of cooking. In the dead of winter I can go thru over 100# in 3 weeks running the furnace.
Aaron
WBCCI #XXXX AIR #2495
Old 03-06-2007, 03:45 PM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
sounds like time for a thourough leak check
Old 03-06-2007, 03:58 PM   #5
1986 32' Excella
vledder , drenthe
Images: 8
outside temp is about 10 c inside 21 c
no cooking no water heater
dubbel windows.
No propane smell inside or around the trailor
Old 03-06-2007, 06:59 PM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Remco, if you're in the Netherlands, it might be useful to know how large (or small) your propane tanks are. They're a somewhat different size from those common in North America, or?
Lynn
WBCCI 21043
Old 03-07-2007, 01:05 AM   #7
1986 32' Excella
vledder , drenthe
Images: 8
I have the original propane tanks
they are filled with 10 kg propane that's about 23 lbs
remco
Old 03-07-2007, 02:41 AM   #8
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
Hi Remco,
what btu is your heater? With the outside temp at 5 Celcius(40f) My 30,000 Suburban NTs will go through a 8kg(19lb) tank in about 48 hrs! Needless to say, I dont get those dinky tanks to fit in my aluminium case any more(we don't get refills in the UK, you have to exchange empty for full). The smaller tanks cost about $2.50/lb. I have 13kg(32lb) or 19kg(45lb) which work out at $1/lb. They're all ugly, orange things but I don't turn into a miser when the place gets warm! Lol!
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 03-07-2007, 07:04 AM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Ok, the nearest comparison to a 23 pound tank for North Americans would be the bbq tanks, which hold ~20 pounds of propane. (The larger tanks often fitted to RVs in NA do ~30 pounds.)
It does sound to me like you're using quite a lot of propane, but it's still possible, I think, that you're actually using the propane (and not leaking it out). I guess it depends on how much you heat and how lot you like your water!
Lynn
WBCCI 21043
Old 03-07-2007, 07:09 AM   #10
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I agree...time for a leak check. Boondocking for nearly a week, fridge on LP, running the 25k BTU furnace all night, each night (it was warmer during the day), using both the stove and oven, I used maybe, 1/2 tank...maybe even a bit less.
Of course, as Shari said, there are lots of variables, but even in the worst senario, I can't see 2 standard size LP tanks supplied by the factory that were filled correctly going empty in 4 days.....
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 02:10 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
