Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 05-04-2008, 08:14 PM   #1
wacnstac
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
How to fix air conditioner shroud
Hi,
I have a 1979 31' International that I basically use as a "park" model. This winter there was 3' of wet heavy snow on the roof and I decided to pull as much of it as I could with a plastic shovel. Unfortunately I hit the brittle shroud and took out this chunk.
I had hoped to find one solid piece to epoxy back in this spring when the snow melted. Unfortunately the largest intact piece I found was about the size of a quarter. I really don't want to spend the money on a new one and it doesn't look like the old one would be too easy to get off since someone siliconed all the bolts into the shroud:
Is there some sort of bondo/plastic resin that could be used to repair such a hole in place?
wacnstac is offline   Reply With Quote
Old 05-04-2008, 09:09 PM   #2
AlbertF
Profile:  1975 27' Overlander
In the Kootenays , BC
Others have successfully used fiberglass repair kits. Right next to the Bondo at your favourite auto parts store.
AlbertF is offline   Reply With Quote
Old 05-04-2008, 10:15 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Originally Posted by wacnstac
Hi,
At best, a patch is a patch. In time, more areas will break.
We have fiberglassAC shroud replacements.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 05-05-2008, 07:44 AM   #4
wacnstac
Images: 41
I know you sell the replacements Andy but I'm not sure I want to put that kind of money into this old bird. Is it an exact replacement for this unit? How does it bolt on there? What if the nuts and bolts are all rusted and seized up?
Old 05-05-2008, 09:12 AM   #5
Commercial Vendor
Our shrouds are exact replacements, since we have the original molds from Airstream.
However, our shrouds are made with fiberglass, not plastic.
They mount the same way as the originals.
Replace the bolts as necessary, which you will have to do regardless.
Inlandrv.com
800-8777311
Old 05-05-2008, 09:21 AM   #6
wacnstac
Images: 41
So this part: http://www.inlandrv.com/parts/69831-acshroud.jpg is the exact replacement? Doesn't look the same. Mine looks like it is a one piece part. Also what does one do to screen in the holes on one of your new parts?
Old 05-05-2008, 09:22 AM   #7
FrenchBern
Profile:
I fixed mine 4 years ago using coarse weave fiberglass cloth impregnated with gorilla glue. All screw holes were reinfored and all holes filled. Cost was less than $15.00 and it is holding on great. 1970 original schroud.
Live and LET live
FrenchBern is offline   Reply With Quote
Old 05-05-2008, 09:41 AM   #8
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Just did a similar repair last week! A tree branch shattered the rear corner(with a little help from me). I used laminating resin and fiber glass cloth on the inside and bondo to finish the surface on the outside. I replaced the hardware with stainless. A peculiarity I noticed was that the front mounting holes appeared to have pulled the shroud downward, that is, the shroud apprears to have about an inch clearance above the air conditioner, based on the two interior rear baffles and the height of the sides. Your pics. also show a bowl like depression just like mine. I put a pair of standoffs between the unit and the shroud to make up the difference. I think it's better, but I don't know why it wasn't done that way to begin with?
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-05-2008, 09:42 AM   #9
bobfowler
bobfowler's Avatar
Profile:  1972 Argosy 20
2007 Base Camp
Middletown , New Jersey
Images: 14
Fix 29 year old plastic that sits outside in the UV? I'd bite the bullet and replace it.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
bobfowler is offline   Reply With Quote
Old 05-05-2008, 09:46 AM   #10
Commercial Vendor
Your AC shroud is 2 piece.
If you took the molding off, you will see how the 2 halves are joined together..
The mold that made your shroud, is the same mold that we have.
Patching the old plastic is OK, but you still have the old plastic, that will continue to crack in other places.
Inlandrv.com
800-8777311
Old 05-05-2008, 09:46 AM   #11
Excella CM
Excella CM's Avatar
Venice , California
Mine did not seem excesssively brittle or frangible. I think it's probably beter than new.
Old 05-05-2008, 10:27 AM   #12
wacnstac
Images: 41
What do you use for screen material in your new shroud and how?
Old 05-05-2008, 11:23 AM   #13
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Take a look at the web site of forum member TomW. He describes a method (that I also used) to rebuild his cover. Worked well for me.
What is that line from "Miracle on 34th Street"? Something like "Maybe he's only a little crazy, like those men in Washington."
www.nesa.org
Air No. 6427
Beat up Air Conditioning Shroud wacnstac Furnaces, Heaters, Fireplaces & Air Conditioning 19 01-25-2007 08:18 PM
Ideas for covering air conditioner shroud for winter wacnstac Winterizing, Storage, Carports & Covers 4 10-22-2006 04:56 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
Air Conditioner Shroud Joe62984 Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-18-2005 08:02 AM
Replacing Air conditioner shroud JD85EXCELLA32 Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-04-2003 06:23 PM
