Old 11-10-2008, 11:39 AM   #1
islander1965's Avatar
1972 27' Overlander
Newark , Ohio
How do I find my furnace model?
I am new to the Airstream world and could use some help. I just recently purchased a 1974 Overlander. It has a Therm'x catalytic heater and a Suburban furnace. The Therm'x has a faulty gas valve and I can't find replacement parts anywhere. The furnace appears to have a problem as the pilot lights, but blows out with a puff of flame coming out the inspection hole. I assume a previous owner had problems with the furnace and put in the Therm'x. I want to purchase a new or newer furnace to replace the original.
Thanx
islander1965 is offline   Reply With Quote
Old 11-10-2008, 11:48 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
A 74 Overlander most likely had a Surburban NT-32FCA.
Richard
Old 11-11-2008, 11:55 PM   #3
outofcontrol's Avatar
1996 28' Excella
Portland , Oregon
1981 Airstream Excella Moho 28'
since I just went out to see what I have, I'll tell you where I found my model number. There's an access door on the interior side of the furnace, I took that off, and read the numbers off a plate inside. It's a Suburban, model N 30M. sorry about the crappy pictures, but it's my cell phone, and they're worth 1,000 words right? -Kevin
ID:	71304   Click image for larger version
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
outofcontrol is offline   Reply With Quote
Old 11-12-2008, 07:57 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Sounds like the furnace is igniting. Make sure that the thermostat is set to "off", so it doesn't try to run. then light the pilot. then put the cap back on the access port. then you can turn up the thermostat to call for heat. If you try to run the furnace with that cap off, yeah, flames will shoot outta there in a scary fashion.
(I wouldn't assume that the therm'x is there because the furnace was bad; people use these for boondocking situations, when there is limited electricity. The catalytic uses no electricity; the propane furnace uses a LOT of electricity. It can run a single battery down overnight.)
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-13-2008, 01:31 PM   #5
1972 27' Overlander
Newark , Ohio
Thanx for the help
Thanks for the help. I am glad that I found this forum with people who respond so quickly.
Old 11-13-2008, 07:42 PM   #6
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Islander1965
Get that thing whipped into shape We got alot of campin to do next yr. We missed 9 weeks of good campin this year because of bad axles. We had to wait on Henshen Engineers to reinvent the wheel.
There people from your area and Akron and up by Cleveland that are active with FORUMS Rallys I know U will enjoy them,They are all really great people.
That Furnace might just need a good cleaning and maybe a new thermo couple. Ours also has a Catalytic heater which we like.We used it on the first trip out in April, it came in handy. I have not had our furnace lit yet either. PO left me alot of little souvenirs. I'll explain over a campfire next yr. Remember to open one of the roof vents Cats do use up Oxygen.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Where would I find a post on Airstream Year Model Changes? Cursh Trailer Values 15 11-16-2008 06:39 AM
How can I find specs and model line up for mine? ob1coby Member Introductions 1 04-15-2007 05:52 AM
How to Clean The Furnace? model NT32CA Gkiesel Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-09-2006 12:46 PM
1960 tradewind furnace what model? scottanlily Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-09-2006 06:50 AM
New Find Chris C 1960 - 1964 Overlander 14 11-12-2005 07:00 PM
