Old 07-06-2010, 05:30 PM   #43
Lothlorian's Avatar
Loganville , Georgia
very informative post because my airconditioner just started to leak back into the trailer. I have to disagree about using anything with chlorine in it. Chlorine will eat up aluminum fast. Chlorine on aluminum is a big no no.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 04-26-2011, 05:40 PM   #44
FullTimin2HI's Avatar
2004 28' International CCD
Palm Beach County , Florida
I'll second that bleach is a no no in a/c systems... Vinegar is a great substitute that will kill all the slime in a drip tube... I prefer to use those little blue tabs that are available at the Orange Big Box Store at the a/c department, but I still haven't figured a convenient way to get them into the drip tray... Any ideas?
FullTimin2HI is offline   Reply With Quote
Old 04-26-2011, 06:17 PM   #45
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Hmmm, you guys got odd problems (maybe high humidity). I've posted before about using a small air compressor and blowing the lines from the bottom. The heat of the compressor should get rid of any growth without damaging the system. Works for me.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 04-27-2011, 12:36 AM   #46
On my unit I switch off the electricity supply to the device, drop the internal cover by removing the control knobs and a couple of screws, and the edge of the one side of the drip pan can just be reached to drop the tablets where required.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 04-27-2011, 06:16 PM   #47
Nice one Nick! I'll take a look next time I'm feelin' industrious! Thanks!
Old 08-04-2011, 08:36 AM   #48
2008 19' Bambi
Decatur , Alabama
Can someone tell me on a Bambi 19 where the exit point is? I looked under it and see no drain tube. There are tubes running everywhere but no down drip type tube.
Nightwind15 is offline   Reply With Quote
Old 04-30-2013, 01:40 AM   #49
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My AC in our newly acquired 2008 Classic 25FB leaked onto the hall floor this weekend camping trip. I took the air filters off and there was a lot of water inside the plastic cover on the left front corner. Removing the cover showed this had been occurring more than this trip and maybe the PO didn't know about it or cared. Once the plastic cover is off there is a large metal plate expose where the plastic outside cover screws onto..The is an hole for air to be sucked in right over the were the water was collecting in the plastic cover. I could barely reach in with my hand and felt water on the inside of the metal plate. It seemed to be coated with a dense padded material. I could feel some sort of tray with water in above this metal cover it when I stuck my hand further up the air intake area.
I have a laundry list of major problems with this AS and will take it back to the dealer I purchased it from in a few days to have the 90 day warranty take care of it.
Kelvin
Old 05-01-2013, 01:16 PM   #50
KJRitchie's Avatar
2008 25' Classic
Looks like my 90 day warranty is only for stuff that breaks; AC, water heaters stuff like that so anything like water leaks is maitenance so i will be attempting to get to the bottom of this.
The large metal plate has some long screws and is probably the main way the AC is secured to the roof. If I remove this plate will it give me better access to the drip pan so I can gain access to the drain hole to blow air etc into it. I'd like to clean the pan too. Is this possible or do I really need to go on the roof.
I'm too scared to go up to the roof for fear of damaging the roof when steping on it.
Kelvin.
Old 05-02-2013, 05:59 AM   #51
2011 28' Flying Cloud
chanhassen , Minnesota
I've found if my trailer isn't level the a/c will leak.
Thank You,
Ken Tuvman
kentuvman is offline   Reply With Quote
Old 05-02-2013, 09:22 AM   #52
KJRitchie's Avatar
2008 25' Classic
Mine was level for the fridge. I level using a round bubble level in the freezer floor and then check the level on the floor adjacent to the fridge. I've noticed when the fridge is level the kitchen counter is off. A pencil on the countertop if pushed will roll to the curbside wall on the counter. Looking towards the front of the trailer the water was dripping into the left front chamber of the plastic housing.
I guess its a cool feature to have AC condensation run down a tube so it dumps on the ground from the wheel well vs just discharging it out the side of the AC on the roof but when it goes wrong its a PITA.
Kelvin
Old 05-02-2013, 10:46 AM   #53
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It has the potential for making a mess if there's gunk in the line, but if you can locate the end of the drain line on the underside of the trailer you can blow air through that direction as well. It doesn't help you with cleaning the pan, but might get the line cleared.
David
Old 05-02-2013, 12:24 PM   #54
Chasmorgan's Avatar
1999 23' Safari
On my home AC condensation pipes i use a shop vac to suction out any debris or fungus. It really works well. My AC guy gave me the tip. Might work on your trailer too.
Charlie M
TAC TX-6
Chasmorgan is offline   Reply With Quote
Old 05-02-2013, 01:18 PM   #55
Pileus's Avatar
1985 31' Excella
Seguin , Texas
I cleaned my AC drain tube from the top down. First, I disconnected the tube from the drain pan and fed a length of line trimmer into the tube inside the Airstream until the line emerged at the bottom end of the tube outside the Airstream. Then I pulled the line on through from the outside. Clearing the tube from from topside to bottom will ensure that trash is not being forced up the tube into the drain pan where it remains a problem.
The second step could have been to use my air compressor to blow the line free--again from top to bottom. But I elected instead to try a hydraulic flush. I had a plastic food syringe (veterinarian supply) that fit snugly into the tube. I injected enough hot soapy water into the tube until it drained freely outside. A big mess of fibrous gunk came out. It was some sort of insect nest.
My AC drain tube has been free ever since.
Pileus is offline   Reply With Quote
Old 05-03-2013, 04:44 AM   #56
KJRitchie's Avatar
2008 25' Classic
I can't see how to gain access to the vent tube from above. Attached a photo of my AC inside vent cover removed. The front of the AC is toward the bottom of the photo. The area where the water was draining into the plastic vent house is the lower left where you can see a double wire crossing. That hole I can peak through and see to the top of the external housing. I can barely get my hand up there but I could feel moisture and I think I felt the drip pan. It didn't appear to feel like a very deep drip pan unless its shallow at the edges and deeper in the middle to promote runoff towards the drain tube.
I think the drain tube is that gray clumpy object in that same area. AS must have covered it with gray caulk. Seems a short section of foam pipe insulation would be better.
Is it safe to remove this metal plate via the three bolts without jeopardizing the integrety of the AC seal on the roof? I don't want to fix this issue and introduce an outside leak.
Will removing this plate gain me better access to the drip pan and where the tube is connected so I can clean it better and use the weed trimmer line to run down to the outside wheel well?
Kelvin
Name:	AC Interior (1).jpg
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Armstrong drain lines davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 09:01 AM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
